Question about Dell A960 All-In-One InkJet Printer
Printer jam It will not feed straight in. It will only feed the right side of the paper, then it crumbes.
    Sergeant:
  • 279 Answers
Sounds like something is stuck in the track. Try taking the cover pieces off and looking for something lodged in there.
Posted on Aug 28, 2007
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
I am using Canon Pixma MP145. Paper gets jammed every time i want to print. Paper gets pulled in only from right side and it gets jammed, but printer does't show any error. I have to pull the paper...
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
The rollers may be dirty or sticky and causes the paper tonot feed straight.
Jul 14, 2011 | Office Equipment & Supplies
Paper feeds crooked and results in a paper jam.
Assume every time this happens something microscopic fell into that tiny pinch of an area. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over and shake it around til the little bugger falls out.
Oct 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
The paper will not feed correctly. The Right side is getting jam
First jam a paper on purpose then you will know where the jam is . and you will also know where to find the paper which is under the white cylinder.
Feb 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper will not feed straight and couses paper jams
Just try these steps:
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck..
Nov 24, 2008 | Lexmark X2500 All-In-One Printer
Paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Nov 04, 2008 | Dell 948 All-In-One InkJet Printer
My epson cs7800
I had the same problem and found a small spring was loose and interfering with the paper. The Spring was on the right side as you look at the printer, near the bottom of the paper feeder. I took it out and it works fine, for now.
Jun 15, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Sep 22, 2007 | Lexmark X1270 All-In-One InkJet Printer
Canon Pixma Printer
Unload all paper. Examine the feed track for any obstruction- paper fragment - cookie crumbs. Take a vacuum nozzle to it and give it a good suck out. Now feed a heavy weight paper/thin card through. Did it do the trick?
May 23, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Paper does not feed - GRABS RIGHT SIDE
I've had this error for the last 2 months and periodically tried to fix it. - I finally read a suggestion to try to push something thicker than a plain sheet of paper through. I cut a side of a manilla folder into a 8.5"x11" and let the printer try to grab it during a copy. After doing it's normal "grab the right side until it's skewed and stop", I continued to try to push it through. I wasn't able to push it to the printing area, but I saw that a piece of something (not much bigger than a bread crumb) came out of the feeder into the interior print area. - I tried another copy, and it was very slightly improved but still skewing and jamming the paper. Suggest unplugging it before performing this...I then lifted the interior piece of plastic (white color for my Pixma MP 150 - which would be located above the paper as it was fed into the print area) slightly to allow any jammed items to come through. Out comes small pieces and then a larger piece of cracker (about the size of 1/4 a cheez-it). Ok I feel dumb, but I'm glad I found something. I picked out the crumbs and did a careful vacuum in the interior and exterior paper feed. Slight warning: The foam bottom below the ink is not secured and will get sucked up by the hose. And note, that I did try vacuuming the intake and interior previously with no improvement. The nozzle on my vacuum is too large to get into the bottom of the exterior intake. - For good measure, I also picked up the printer and turned it upside down and shook vigorously in a couple angles. I saw a couple more small crumbs come out. - My printer is now feeding the paper correctly and successfully made a copy/print.
May 18, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Dell A960 All-In-One InkJet Printer Logo
60 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
