Question about Kenmore Oasis HE 27062 Top Load Washer
Washer problems after starting a wash about 25 seconds later the washer stops and the code (F1) appears what causes this.
  • mrsbnme3 Nov 02, 2007
    i have the same problem kenmore is at myhouse now $ 364 to fix needs main computer......AAAAAAHHHHHHHHHHHH
  • jlbbachman Sep 08, 2008
    How do u fix it yourself?
  • 3 Answers
I did it myself..sears told me $350 it bouth the part for $130 and took me about 30 minutes to figure it out. What a scam. The machine was 1 year and 1 month old. and I need a main componant like that??? Out of warranty I was told.....
Posted on Dec 27, 2007
Replace the computer yourself. takes 20 minutes very easy and part is about 150.00, I did mine.
My washer stops &and F-20 appears on viewer. Whats wrong with my washer
water problem check screens in hoses and valves !! rrors F1, F11 and F20
  • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
Washer starts to fill then stops /now warsher wont wash
I too was having the same problem and I almost paid to have it repaired, which would have cost a few hundred dollars, thanfully I called the recall line after reading some of the other post on here and my machine was elgible for a upgraded on the control panel so didn' t cost anything for us. Sears told us that the F1 code is a miscommunication in the control panel, basically the machine is confused and don't know what to do so it stops and gives that code. Hope it helps!
Jun 19, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I turn on the top load washer ,it starts to fill
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 13, 2009 | Kenmore Washing Machines
The washing stops 3 times when you first start it with the codes F1 on display then 3 more times with 19 min. left with the codes F1. What is F1? Everytime it stops I press the stop button then start...
This F1 Code is a Communication disconnection problem between the Control Unit and the Electronic Curcuit Box. First Check the Connection and reply me with the make and model no.
Sep 21, 2009 | Washing Machines
When the cycle starts F1 appears on the dial,
Here is a link to the service repair sheet at Whirpool for the F1 error code on your machine. You will find 4 things to check at the bottom of the page. Good luck.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/1a4cb9c9ab426640852574e90050e40f/$FILE/8178767.pdf
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code on Kenmore Oasis He
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Cabrio F1 code
have the same the washer show F1 I have to hit pause start 3 time befor it will wash severly people have the same proble with this whirlpool washer it is a tiner proble i hve been tool.
Jan 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
New to this Machine. Unit washes and stops every 25 seconds?
Have you contacted Malber USA? 516-294-6660. They were helpful with my problem.
Aug 17, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
70 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
