Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Fuse for dishwasher (bosch)
Hello
I enherited a bosch dishwasher from my uncle and finally just fetted it in the kitchen but i had to cut the plug off to thread the wire through a hole to get to the socket. I put a new plug on and a 13a amp fuse but now the dishwasher isn't working. Am i using the wrong fuse?
Thanks
Clueless and in need of help!
  • angelaclarke Oct 18, 2008
    Thank you Tresilla,
    I later found out that the socket isn't working! But now i have a new problem!
    I have switched on my dishwater and turned the tap on under my sink for the water. I can hear noises from the dishwasher but it's not using the water! Do i have a blockage? This dishwasher has been sitting in my garage for six months.
Don't cut plugs off in the first place...
Posted on Nov 08, 2008
I know this sounds daft but try it.
tilt the appliance back at 45deg and see if water comes out of the base. if so, drain the water this way and the machine should start. if fault reoccurs, then you have a leak and come back to me.#
if there is a leak, then this may well be due to rodent damage. mice love rubber hoses! (not kidding)
Posted on Oct 20, 2008
    President:
  • 1,462 Answers
13a fuse is correct. have you wired the plug correctly and is the fuse you are using a good one? try substituting a known good fuse ie from your electric kettle or whatever
Posted on Oct 18, 2008
Bosch custom panel dishwasher
Use the add image function here to attach a picture of your installation
Mar 17, 2014 | Dishwashers
How do you clean your airgap on a bosch dishawer error 24
my Bosch dishwasher will not come on packed in half way through wash there is no power at all checked fuse in plug any ideas do they have a cut out on at all
Mar 30, 2013 | Bosch Dishwashers
How do I reset an old Bosch dishwasher SHI4302UC ?
Assuming that you can control power to the dishwasher from your kitchen panel switches, hold down the power on switch on the front panel of the dishwasher and recycle power (switch off and on) at the kitchen panel switch.
This will reset the dishwasher.
Sep 26, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Remove the top from free-standing-dishwasher bosch sgs43c12
hello martin - yes you can remove the top. And no, it will not harm the dishwasher funcion.
Aug 02, 2009 | Bosch 24 in. SGS43C12 Classixx...
I cannot be sure of the make/model - there is no power
It sounds like you have a bad controller which is an expensive part if it is over five years old. However, there is a recall on some Bosch dishwashers which involves replacing the control. If you call Bosch at 1-800-944-2904 they can tell you if your model is involved in the recall.
Apr 17, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch snu 6806
Have you checked the breaker? Is the dishwasher on its own circuit or on shared circuit with the kitchen outlets? If shared with the kitchen, might one of your GFI's be tripped?
Aug 04, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch wont
Faulty inlet valve or water in the bottom tray which will activate the float swich and pump out any water. See that this moves up and down freely. Turn electrics off first.
Jun 18, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch dishwasher
hi there first i would confirm you don't have power supply issue, replace the fuse and try different power outlet failing that it is quite common for bosch on/off switchs to burn out.
hope this is of some help
Dec 14, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
610 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
