Question about Pentax K100D Digital Camera
Pentax K100D Thanks to answer My camera falled on the concrete floor. Even if it is linoleum, the body slightly opened from the bottom, so the left door (where dc in and usb plugs are) does'nt close well. I've once broken an argentic camera years ago and I dont want to open tha digital one without knowing what to do. Does it exists a plan of theses machines ?
    Scholar:
  • 58 Answers
There is no online diagram you can reference. I would not recommend attampting to open the camera yourself.
If you insist on attempting this, I advise first removing the batteries and leaving it of 24 hours at least. There is no knowing where the high voltage components for the flash unit are, and they will give you a nast electric shock if touched, and if they are accidentelly shorted to any other part of the electronics will destroy the circuitry.
I woud leave this to a photo repair specialist. Preferably your nearest Pentax authorised dealer.
Posted on Jan 21, 2009
Picture is not displaying on sony dsc-hx1
Talking about two camera's my guess is you made a picture with a Pentax K100D and you put it on the memory card in a Sony dsc-hx1.
In the manual the Sony tells what sizes of pictures it can display. None of the 4 sizes the Pentax K100D makes, is in that list.
Perhaps you don't mean this, please let me know.
Oct 29, 2013 | Pentax K100D Digital Camera
New Pentax K100D Super, shutter does not work. Av -- flashing 688 under battery sign. Replaced new batteries did not resolve problem
I suspect dirty contacts on either lens or body. Clean contacts. Should alleviate problem. This happened to my K100d.
Dec 11, 2010 | Pentax K100D Super Digital SLR Camera
Won't focus or take picture
Try cleaning the contacts on the camera body with a cotton swab lightly dampened with rubbing alcohol.
Jan 05, 2010 | Pentax K100D Digital Camera
Won't turn on even with new batteries
Clean the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol.
Dec 17, 2009 | Pentax K100D Digital Camera
What Memory Cards will work?
Hi,,
Unfortunately, the Pentax K100D is not SDHC compatible, which means that the camera can be equipped with a maximum memory capacity of 2GB.
It is also advisable to choose a fast version of the Secure Digital memory card, such as Ultra II or Extreme III by SanDisk. I would recommend using a memory card of at least 512MB, or even 1GB if you can.
Hope this info helps
Dec 03, 2009 | Pentax K100D Digital Camera
Memory Card error message
The K100D works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot is is electronically incompatible.
Sep 25, 2009 | Pentax K100D Digital Camera
Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Dec 31, 2008 | Pentax K100D Digital Camera
Pentax K100D super lens problem
Read the K100D manual. Go to the Setup menu and allow for lenses with manual aperture settings.
Aug 04, 2008 | Pentax 100-300mm f/4.5-5.6 SMCP-FA Zoom...
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT...
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
Jul 14, 2008 | Pentax K100D Super Digital SLR Camera
Pentax K100D Digital Camera Logo
110 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
