Question about SAMTRON 55V 15" CRT Monitor
Dead when i press the power switch the led turned off after 1 second . power cable is ok
    President:
  • 3,130 Answers
This is an idication that the Hi voltage didnt start up. My experience with these monitors tell me the flyback and horizontal output transistor is bad and probably not worth to repair unless your a tech and know your way around tv circuitry. Its not advisable to go into these sets as there are no user serviceable parts inside. good luck
Posted on Jun 10, 2006
I have a sharp television 14 inch. the problem is when i switch on the primary power switch the led turns red then pressing the secondary power the the led turns green then just about a second a click
It is self-shutting down Something electrically bad inside. Could be anything. Usually some type of overload on power supply. Need training to troubleshoot.
Nov 23, 2014 | Sharp Televison & Video
My HP G60-230US Computer will not start. The computer is a little more than 2 years old. Every so often when I would start the computer it would say "No boot device found". I would restart the...
sounds like your motherboard malfunctioned. the board was probably starting to go out. thats why it would see the hdd then not.
you sound like youre familiar with computers. you may want to invest in diagnostic cards to troubleshoot problems like this. theyre fairly inexpensive on ebay. basically you insert the card into pci slot and it displays an error code. then you look up the code in a book. works like the obd2 reader for your car.
good luck
Feb 28, 2017 | HP G60-230US Notebook
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
I neid go know how to reprogram one of the controls for the tv in a room but i lost the control for the tv in my living room, in the living room i have the cable box.
jc4lifes3as
I have provided instructions on how you can program your remote to your TV. Without knowing the brand TV you have, I have provided a link with the codes you can try.
Program to TV:
Remotes: Basic (Television Only)
1. Turn the Television On.
2. Press and hold the TV Power button for three seconds until the LED flashes.
3. Enter the three-digit code using the buttons on the number pad.
4. Press OK. Note: The LED will flash three times.
5. Test functionality with the TV.
6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Power Scan:
Remote: Basic Remote (Television Only)
3. Press and release the TV Power button.
4. Press and release the Up or Down Arrow on the remote until the television turns off.
5. After the television turns off, press and release the OK button.
6. Test functionality with the TV.
7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
The link for the remote codes are at the bottom of the page. Select your receiver type and then your TV brand to get the codes.
http://www.dishnetwork.com/SupportSection/remote-setup
I hope this helps.
Ray Calo
DISH Network"
Apr 16, 2011 | DISH Network IR Remote Control
I have HP Officejet 5610 All in One printer, When i am switch on the power button the dispaly showing intializing and after a few seconds it shows date & time and then suddenly one noise coming from...
Its time to reset the printer; follow the below steps
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
Nov 27, 2010 | HP Officejet 5610 All-In-One InkJet...
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
Aug 25, 2010 | Ford Focus Cars & Trucks
Canon mx300 not printing
Hi
It is ink low error U051
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Or try this
Here the Solution to reset the ink level for Canon Pixma MX300 follow this steps to reset the ink level in your canon MX300.
  1. Switch off the Canon MX300 and disconnect the power cable.
  2. While press and hold the power button, Connect the power cable to electric socket.
  3. While pressing the power button, press the “Cancel/Stop” button (red button).
  4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says “idle”.
  5. Press “>” (next button) once “Shipping Mode 3′ then Press the “OK” button. Press “OK” again for “without cleaning”.
  6. A test page will print.
  7. Open the cover, like you are about to change the cartridges.
  8. Disconnect the power cable again without switch off the printer.
  9. Take out the both cartridges.
  10. Close the cover.
  11. Connect the power cable and turn on the printer.
  12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 02, 2009 | Canon MX300 Office All-In-One Printer
Compaq Presario F700 turns off just a second after the start button is pressed... any ideas?
try holding the esc button when turning on the notebook the power button light should stay on if the hp logo doesnt come on then turn it off and unplug the notebook and unplug then remove the battery plug the notebook and hold down the esc button and start it let the notebook on for about 1/2hour then turn it off and unplug it put the battery back on and plug it press the power button and it should show the hp logo press f10 to go in to bios then change time and date to current and allso change the boot order
Aug 20, 2009 | HP Compaq Presario F730US Notebook
My maytag dishwasher appears dead just after 1 year
You probably have a bad main control or console control unit in there. Turn power off to the machine, be sure that BOTH of your door switches are ok. Unplug your membrane to control panel ribbon cable, then put everything back in place. Leave the door open, then turn power back on to machine. (also, be sure the thermal fuse hasnt tripped while your in the console). After re-appling power, close the door, and wait a few, if the console unit is bad, the machine will go into drain mode (you will here the unit start in drain). If no drain mode, then your control is shorted. You dont have to see any burn marks, etc for one to be bad, in fact, 98% of the boards we replace, dont show any signs of problems. Let me know what you find out.
Nov 15, 2008 | Maytag 24 in. MDB5600A Jetclean II...
SAMTRON 55V 15" CRT Monitor Logo
125 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
