Question about Pioneer Audio Players & Recorders
Pioneer elite vsx29tx receiver. upon powering up, turning it on it seems to take 2-3 minutes before sound appears, and other days it may take 10-15 minutes for sound to happen. when switching listening modes cinema, stereo, standard, direct ect. the sound may dissapear and only return in the direct mode. regards, brian
5 Suggested Answers
silly girl
  • 513 Answers
SOURCE: Losing sound in certain modes
I get the same problem with my Nakamichi, but it never bothered me much, since i can't notice any quality drop, besides, its only radio. I remember it happens only on certain stations though, which leads me to believe it might have to do with the broadcast itself which oscillates and varies in amplification from station to station, and is affected by weather and geography. If it really botheres you, try getting extra juice amp for your tuner from some specialy electronic store. Good luck
Posted on Mar 26, 2006
  • 151 Answers
SOURCE: Onkyo receiver TX-DS696
If you get sound on direct mode say from dvd but no sound when you go to dolby make sure you have the right input selected by pressing the digitat input button on the front of the amp,ie if dvd optical out is pluged into amp optical input 1 select this on amp then set audio to prologic2.DVDs through this input will decode to dolby digital/dts.
hope this helps.
CABLE GUY.
Posted on Jun 29, 2008
  • 4234 Answers
SOURCE: I have a Aiwa Stereo Receiver Av-D58. The sound
If I remember this model correctly, there is only 1 direct input. The remainder of the inputs are bufferred through a switching IC. It is likely that this IC is defective. Are there any other symptoms at all?
Thanks,
Dan
Posted on Mar 13, 2009
palaboy
  • 5807 Answers
SOURCE: I have an Arcam AVR250
hi,
Sometimes it happens. ( age ) or possibly cold solder
joint or mis communication on the Digital Controller
and DSP Unit.
• One way to check is to verify each input if it can pass
output ( line Out ) signals.( at the back of the unit )
• If it does then you just have eliminated a large percentage
on electronic circuits troubleshooting.
• There are more details or info starting
on page E 25 of the manual
[PDF] Download the owners manual - Arcam AVR250 surround sound receiver
have a recheck and triple check on the settings.
But if you need a thorough investigation on the DSP
circuits , it might need a service manual
http://www.service-manual.net/ashop/catalogue.php?cat=300
only with a fee.
And be the last resort as to confirmed if it is really the DSP.
• You can use an external amplifier or a signal tracer when
probing signal outputs on the receiver.
• Here is a link for sample troubleshooting :
a ) Start with the input , then to the op-amp IC. b ) check your cable like those above for co
these unit is just a guide, not the same as yours , but the
process o f troubleshooting and principle is the same.
Only if you feel to DIY.
Posted on Aug 27, 2010
Pioneer VSX - 26 TX single-processor receiver elite no sound work fine one day turn on have no sound checked all the connections everything's good here clicking in the receiver can you help me
You may have overloaded your amp. If you have a separate amp in line then this would not be the case but if you are using your receive as the amp then it could be. Look for a fuse on the unit. Usually a small black square marked with 15a.
Dec 03, 2015 | Pioneer Audio Players & Recorders
Sound takes 10 minutes to come on from my Pioneer Elite 94 av receiver
I supose this is not how its suposed to work, only thing I can think of is somekind of a hardware side problem, Im sure you still have warranty on it, if you can you should go and get it replaced.
If you need more assistance let me know, I'm here to help
Apr 13, 2008 | Audio Players & Recorders
Pioneer VSX-60 Volume Decrease each 2 min
it's a somewhat common problem with that model. It needs a new cpu board.
Apr 21, 2014 | Pioneer Elite VSX-60 7.2 Channel Network...
Good day, I need your asst. I can't seem to remove the 2ch playback from my VSX-49TX Elite Pioneer reciever, I tried reseting it and nothing happen...can you help me.
If you have no sound, you can try the multi channel inputs on the back after switching to the multi chan input. If you have sound that way, you have a DSP problem. I can repair this issue to the component level, as many customers have found, the boards are very expensive, and no longer available. If you're interested in repairing your receiver, please visit my website at audioserviceclinic.com. There you will find the seminar I wrote for Pioneer, when I worked there as a Field Service Engineer, specializing in audio. You can contact me directly from my website. Thanks you.
Jul 14, 2011 | Pioneer VSX-49TXi Receiver
Pioneer Elite vsx-27tx receiver with no bass!?
There may be a subwoofer mute function on your amp. The sub out is nothing more than a preamp output with a low frequency response. It is meant to be amplified by an external amp. Either check your powered subwoofer for operation or look through your operators manual for a sub mute function.
Feb 11, 2010 | Pioneer VSX-27TX Receiver
I have a pioneer elite vsx 36tx receiver that quit working. When I turn it on it just hums. It seems like a power supply but not sure.
I have the same receiver.
Do you mean there is an audible hum from the unit, or that speaker output(s) hum?
Let's figure out what DOES work...
Do you get the audible relay click a few seconds after power up?
Does it tune FM?
Can you get the On Screen Display? Settings all ok?
What preceded this? RSVP.
Jan 19, 2010 | Pioneer VSX-36TX
Pioneer elite tv turns off from a pop sound and manual says-will
It is most likely the power supply. Do not try to fix this yourself. There are LETHAL voltages inside such a TV, which can persist for WEEKS after it has been turned off.
Jan 09, 2010 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Dec 10, 2009 | Pioneer VSX-72TXV Receiver
DVD video stops; audio continues
This definitely sounds like a circuit board-level issue. Have you tried moving to a different input set (i.e. if you're now on the TV inputs, try the DVD or AUX inputs for both video and sound)? Just to rule out the obvious, have you made sure that it's the receiver and not the DVD player? I know that you said you powered down the receiver, but if you had turned it off by pulling the plug on the surge suppressor and your DVD player is in the same suppressor, you might want to make sure it's the receiver and not the DVD player.
If you're sure that it's the receiver, then you might want to look into taking it to a Pioneer service center to have it repaired. If it's not worth the cost to you, it might be time to be looking into a new receiver.
Dec 10, 2007 | Pioneer VSX-D914 Receiver
29 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
