Question about Yamaha HTR-5830 Receiver
Receiver clicks I've had my yamaha receiver now for about a year and about 2 months ago after moving it to a different location and re-wiring up the speakers, the system clicks loudly every so often. Sometimes the click is every 5 minutes and sometimes it's every hour. It's almost as if there's a power surge or if something internal to the receiver is switching. Since moving the receiver I've unhooked and re-wired the system again, but the click remains. Any help is appreciated. Thanks.
  • Ted Elrick Jun 10, 2006
    It's definitely a pop, and we're not sure if it's out of one speaker or many. When you say that one of the parts is breaking down, are the parts in the receiver or speakers or possibly both? I'll definitely be taking it in (assuming I don't get charged an arm and a leg). Thanks so much for your help and a fast reply. I've very impressed with this site.
    President:
  • 3,130 Answers
When you say click Is it a POP out of the speakers?? If the answer is yes then it sounds like a semicondutor such as an IC or driver transistor or preamp is breaking down . You also didnt state if its out of one speaker or both at once. Unless your a tech this is probably something you wont be able to troubleshoot and fix yourself as there are no user serviceable parts in this puppy. Good luck
Posted on Jun 10, 2006
I bought Yamaha RX V565 4yrs ago, then after 2 years, may receiver always shut off 5 minutes everytime I open. What is the problem or reason of shutting down my receiver? Thank you
press and hold both the "DIRECT" and "TONE CONTROL" buttons and press power and see what it says on the display. This will give us some idea of what is causing the receiver to turn off.
Mar 30, 2015 | Yamaha Rx-v565 Receiver
Yamaha RX-V663 turns off right after switching it on
The display of PS2 PRT means there is a problem with the power supply. Could be a voltage regulator gone bad, very hard to tell without getting inside.
Jan 02, 2014 | Yamaha RX-V663 Receiver
About a month ago my speakers started humming-does't matter if the cable/dvd are on, as long as the receiver is on it hums. Figured out it was the receiver since I plugged other speakers into my...
normally a Hum is caused by a bad ground,, if it only happens when the unit warms up it could be the output drives are failing. , check the grounds to the unit first, then the wires to the speakers themselves, if they all check out ok,, you need to take it to a repair shop dealing with receivers
May 27, 2011 | Yamaha RX-V1600 Receiver
Can you tell me please: where do you insert cables from a cable box to a Yamaha RX-V2500 receiver I appreciate any help you can give. OK. The cables that were attached to my cable box were removed when the...
the coaxial cable from outside is connected to in (box), coaxial cable from out to digital in (RX) digital out to TV... (try scrolling through source to cable/ or component if this is HD) (all other devices can be connect to RX also like dvd using Red Yellow White cable or S-video w/red & white)
Mar 12, 2010 | Yamaha RX-V2500 Receiver
My Denon AVR-788 receiver switches off by itself after it has
If you've changed it's location or added speakers, or placed anything on top of it since the problem started then consider that it may just be over heating.
Dec 19, 2009 | Audio Players & Recorders
It keeps goin to protectin mode
Well I have an Onyyo TS SV515 Pro II receiver that is quite a few years old. I have lived in several houses and have moved it with me. For as long as I can remember it has been going into 'protect mode' when I turned it over 6 on the volume knob. I have a subwoofer and 4 infinite speakers and a yamaha center channel speaker.
I got on the internet the today to see if I could figure out why it did this. One person suggested cutting my speaker wires and resplicing it making sure no hanging wires where there.
I had been using the same speaker wire since I puchased it (10 yrs ago). I feel pretty stupid, cause I just did the wires to my front 2 Infinite speakers and WaLa...It works flawlessly. I can now turn up my receiver...after 10 years of dealing with no 'full' volume.
*****Check those speaker connection, they are the key*****
Sep 18, 2008 | Audio Players & Recorders
My yamaha htr 6050
Make sure you speakers are turned on on the receiver,
Jan 23, 2008 | Yamaha HTR-6030 Receiver
Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Jun 05, 2007 | Yamaha RX-V630 Receiver
Yahama receiver Rx-630 not working
The problem might be caused by two major circumstances. 1)Touching wires 2)Overheating. I suggest you unplug all wires connected to the amp then turn on the amp. If it gets turned on then we know that the problem is that you have touching wires. If there is a short circuit somewhere, get rid of it. The ventilation is another important issue that you have to pay attention. It simply causes overheating.
Yamaha HTR-5830 Receiver Logo
95 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
