Question about Sony PCG-TR3A Notebook
Intermittent AC charging
On my Sony laptop PCG-TR3A the battery charging with the AC adapter is intermittent. The power symbol erratically switches back and forth between "battery power" and "AC power." Replacing the battery made no difference. The AC power supply puts out a steady 16 VDC while charging, as it should. I assume the problem is in the charge controller which must be inside the laptop. I have not been able to find a service manual.
Will appreciate your help.
Berni, briechelx@gmail.com 1-831-601-9199
  • Berni2 Oct 19, 2008
    I don't believe that a loose connection is my problem, because the
    intermittent on/off action is the same whether I wiggle the connector
    or not. Wiggling has absolutely no influence on the erratic charging
    behavior.
    Berni
    briechelx@gmail.com
  • Sony Master
  • 4,338 Answers
Your DC connector is loose, it needs to be resoldered.
I could not find a free manual, here is are sites that sell it:
http://www.9manuals.com/sony_sm3.htm
http://www.manualzone.com/ReWrite-SPFM-.ESI.M27834461
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 18, 2008
How to replace internal battery for Sony PCG-955A
If you mean the cmos battery you will probably need to take the laptop apart - if you are lucky it may be under the keyboard - look at the screws on the back and see if any show symbols for keyboards.
There is a vaio manual here.
https://docs.sony.com/release/PCGFX170.PDF
Oct 05, 2014 | Sony Vaio PCG 955A Laptop Universal AC...
Battery/Ac adapter issues for Sony VAIO Model
So I gather the laptop does not run when the battery is in and the AC adapter is not connected? Laptop batteries tend to ware down over time and will need to be replaced as they end up not being able to hold any charge. Look online for a new replacement of the battery under the model number of your laptop
Aug 13, 2013 | Sony VAIO PCG-K33 Notebook
AC adapter power connection LED blinks but not charging
This suggests to me that you need to check out the AC adapter, and see if there is an intermittent short. In otherwords a break in the wires.
AC adapter unplugged from laptop, and power, remove the AC power cord from the body of the AC adapter.
Use a multimeter set to OHM's, (1K), and connect the Positive (Red) probe lead to one of the flat bladed prongs, in the power plug that plugs into the surge protector.
Touch the Negative (Black) probe lead to one of the holes in the plug, that goes into the AC adapter 'body'.
Keep going from hole to hole, until you get a reading.
Now have an assistant gently wiggle the power cable, and see if you get an intermittent reading.
Do the same for the other plug's flat bladed prong.
Intermittent reading means replace the power cable, or if more feasible, the entire AC adapter.
Power cable proves to be fine, move on.
Plug the power cable back into the AC adapter. Plug the AC adapter into power.
Using a multimeter set to DC Voltage, touch the Positive (Red) probe lead of the multimeter, to the center hole of the plug that goes into the laptop.
(If just a symbol, the DC Voltage symbol is a dotted line over a solid line)
The Negative (Black) probe lead, touches the outside cylindrical metal shell, of the plug.
Have an assistant gently wiggle the cable, and see if there is an intermittent reading on the multimeter.
(Reading should be 18.5 Volts DC)
[There are Analog multimeters which have a scale, and a needle, and Digital multimeters that just have a digital readout.
If using an Analog multimeter the needle will drop towards 0.
If using a Digital multimeter the readout will drop to smaller numbers, or 0 ]
AC adapter checks out? Go on.
The port on your laptop where the AC adapter plugs in, is the DC Power Jack.
AC adapter unplugged from laptop, Battery removed.
Take a pencil, and gently use the eraser end to see if you can wiggle, the center pin of the DC Power Jack.
ANY perceptible movement means a problem with the DC Power Jack.
The GOOD news is that the DC Power Jack, is NOT soldered directly to the motherboard.
It slides down in a Channel on the outside edge of the Base Enclosure, and has a wiring harness coming from it.
The end of the wiring harness has a plug, that plugs into the motherboard.
The HP part number for this DC Power Harness is HP 600630-001
A) http://www.dectrader.com/600630-001-New-HP-DC-input-power-socket-connector-With-cable.html#.UD0_w6B0k9Q
B) http://www.ebay.com/itm/HP-Compaq-600630-001-DC-Power-Input-Jack-Cable-CQ42-G42-Notebook-Series-/180932154005?_trksid=p4340.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D1653940420718665976%26pid%3D100011%26prg%3D1005%26rk%3D1%26
This is a link to a free Service Manual from HP Support,
http://h10032.www1.hp.com/ctg/Manual/c02627955.pdf
Page 73 is for the Power Connector Cable.
No damage to the DC Power Jack, and the harness is not slightly unplugged?
Now you have real problems.
You have a bad Power MOSFET,
A) MOSFET:
http://en.wikipedia.org/wiki/MOSFET
B) Power MOSFET:
http://en.wikipedia.org/wiki/Power_MOSFET
C) http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
However it doesn't take a rocket scientist to replace. (Sorry Gort)
These SMD's use a J-lead contact. Simple unsoldering, and soldering.
(Better be fast though as you don't want to overheat a power transistor. Better be good, because you don't want any cold solder joints)
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 28, 2012 | HP Computers & Internet
Is there a software that is associated with my sonny battery that will make it charge again
If you plug in your AC adapter to your laptop to charge the battery and get the "plugged in, not charging" message then try the following solution:
  • Disconnect AC adapter
  • Shutdown laptop
  • Remove laptop battery
  • Connect AC adapter
  • Power on laptop
  • Click the Startup Menu
  • Type Device and select Device Manager
  • Under the Batteries category, right-click Microsoft ACPI Compliant Control Method Battery and select Uninstall.
  • Shutdown laptop
  • Insert laptop battery
  • Power on laptop
    If you follow these steps and find that your laptop still does not charge then consider replacing the laptop battery itself.
    Hope to have been of assistance,
    Thanks.
  • Sep 14, 2011 | Sony VAIO PCG-K23 Notebook
    HI IAM USING SONY VAIO LAPTOP VGN SERIES NR11Z/T WITH MODEL NO.PCG-7Z1M. MY LAPTOP DOESNT USE THE BATTERY WHEN I CAHRGE. PLEASE HELP ME. IAM FACING TROUBLE AS I WILL HAVE TO ALWAYS CONECT TO POWER IF I...
    Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
    Mar 12, 2011 | Sony Vaio PCG 7Z1M Laptop Universal AC...
    My tr3a reboot like every ten minutes when i am using it with the battery?
    1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
    2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
    3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
    4. The motherboard could be defective & needs to be replaced.
    Sep 10, 2010 | Sony PCG-TR3A Notebook
    How to replace cmos batter for sony pcg-tr3a
    I replaced on on a old vaio. It was button battery under th e keyboard. have to be careful not to break the battery holder because the plastic drys out, suggest drop of oil.
    Oct 11, 2009 | Sony PCG-TR3A Notebook
    Sony pcg-tr3a laptop beep continue &notbooting
    Ur ram is not working u need to change ram.this beep is becouse ur ram is nor wroking.
    Plz dont forget to rate thnx
    Sep 09, 2009 | Sony PCG-TR3A Notebook
    Would any 16volt ac adapter be ok to charge my PCG-VX89 vaio notebook?
    you can use any laptop AC adapter DC output-16V and 4A (current). if its jack size natch your laptop DC jack.
    if the adapter DC current less than 4A (over 2.5A at least) you should only make the battery charging without laptop turn on!!!
    please take a rating let me know how much helped you thanks!
    May 21, 2009 | Sony VAIO V505DC PC Notebook
    Camera, PCI Modem, USB devicedriver
    hi! i need some help about my sony pcg tr3/b anyone knows where i can download the driver of the athenos AR5212 wireless adapter for this model of laptop thanks you. pls mail me at vvioxx06@yahoo.com.ph
    Mar 28, 2008 | Sony PCG-TR3A Notebook
    Sony PCG-TR3A Notebook Logo
    172 people viewed this question
    Top Sony Computers & Internet Experts
    Alun Cox
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
