Question about Sharp AR-207 Copier
Sharp AR-207 copier puts .5 inch black line across entire bottom of copy
A few years ago I purchased a new sharp AR-207 copier. soon after I got it, the copier started putting a fairly thick black line across the bottom of each copy. I believe that it doesn't do it right away after machine startup, but after maybe 3 or 4 copies, then every copy has a black line. It of course goes across the information you are attempting to copy.It is not on the original. I am wondering is fsomething went out of adjustment
  • keen27 May 11, 2010
    try to reduce the image and see if the black line comes with the image if it does you need to clean the optics section. You can do that by removing the platen glass and clean every mirror inside, wipe it with cloth..
    But if does not come with the image as you reduce it. then it's a mc problem, clean this also especially the saw tooth. you can find it by removing the toner, then the developer and you can see the drum, it's right above the drum,just unsrew it and there you'll find the sawtooth just clean it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 118 Answers
Does the line only show up when making copies from the adf or both when you put it on the glass. if only when thru the adf the **** glass is dirty. that is the glass that is only about an inch wide. be carefull of the two pieces of tape that are on both the front and back of that glass they fall off easly.
Posted on Nov 12, 2008
How to take out the thin line comimg from my sharp ar153 copier machine
Try cleaning the slit glass. Thin strip of glass under the feeder.
clean it really well with some rubbing alcohol the line should go away.
test by making a copy off of the glass platen.
if you have a line when copying from the big glass you need some maintenance, probably a new drum/blade combo.
Skelton Business Equipment Houston Copiers
EquipMyBiz
Jul 02, 2014 | Sharp AR-153E Toner Cartridge AR153E...
There's a black line on copies of SHARP AR-5316E
Cartridge(s) may be putting out too much toner or scratched
Aug 27, 2012 | Sharp AR-5316 Advanced Digital Imager...
When we make a copy it shadows the image on the paper and puts a black line across the paper.
it seems to be the problem of the drum.how many copies has it yielded .call a rep and change it
Aug 19, 2011 | Sharp AR-M160 Black and White Copier
Sharp AR 207 paper gets lifted out of tray but will not continue to feed into machine. Side feed works fine
try cleaning the paper feed rollers in (above) the tray. and the rollers on the right side (theres 3 gray rollers) If thats works you will need to replace the rollers soon.
Aug 28, 2010 | Sharp AR-207 Copier
My SHARP AR-168D is not recognizing a new toner cartridge.
Make sure what you've got is Sharp's AR168NT and not AR152NT. Sharp mades changes about a year ago to their toner and the chip on an AR152NT will not work with an AR-168D model.
Aug 18, 2009 | Sharp AR-168D Black and White Copier
I have a sharp ar 207 copier. It is giving an error code of U 2. When you press "copy" it gives a code of 40. I cannot locate the service manual. Can someone help?
you have a problem with the chip on the toner cartridge
you have to reset this via simulation 16!
if it's a refilled one have the recycler do it and replace the chip
if it's an oem ask sharp
Jan 25, 2009 | Sharp AR-207 Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-207 Copier Logo
206 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
