Question about HP Computers & Internet
I replaced my hp ink catridges and the printer is still saying the ink is empty. What do I do?
  • 185 Answers
You haven't mentioned what printer model but you can try th following.
Firstly, try removing your new cartridge and temporarily putting the old one back. Sometimes this will then show as a full cartridge even though it is empty, because the sensor electronics appears to get confused. Next, turn off your printer and turn it back on again, then take the old cartridge out and put the new one back. I cannot guarantee this will work, but it will be worth a try.
Posted on Oct 18, 2008
Printer will not print saying that the printer is out of ink. Test shows empty cartridges. Took the cartridges to store, they checked and said they were full, doing a test page to confirm. Is there some...
try clean the gold contacts that touches the printer and the catridge.I remember some of the pins tells the printer the leftover ink in the catridge.
the other thing is, hp ink will 'expire'. there is a fixed date stored in the chip of the catridge. if the date is expired, you cant use the ink regardless its full or empty.
Sep 22, 2011 | HP Officejet 5610 All-In-One InkJet...
My HP Officejet Pro L7650 printer says "Cannot
Hi
Firstly you should check if there is any covering on the ink nozzles
Did you try to allign the print catridges after you changed the same.
Take out the catridges and clean it with a piece of cloth again put it back and check
if still it doesn't work
If you have done it perform a semi full reset:-
Unplug the power cable at the back of the printer
Press and hold down the (#) and the (6) key together pplug in back the power cable
Leave the keys it should say on the screen semi-nvm reset if it doesn't says so its not done properly .. try to do it once again after that it should align the catridges automatically
This should solve your problem if not try with a different catridge
Aug 24, 2011 | HP Officejet Pro L7650 Printer
I put a yellow ink cartridge in printer and it is new but the printer is saying yellow cartridge is empty so i am unable to print anything what do i do
Did you remove the plastic Seal undernith your ink Catridge, also check for any dry ink deposites where the yellow catridge sits in the catridge carriage box, if present use an alcohol cleaning pad to clean the carriage and re-install and verify.
Dec 03, 2010 | HP Officejet 6500 Wireless All-in-One...
Replaced the ink. black works colored does not.
Normally, new catridge has a thin layer close the output of the ink. See that thing. If it close, pull it over, Or.
May be the catridge is not suitable with the printer.
May be the the catridge is quite old and the ink is dry, if it is refill catridge, put several drop of hot water in it.
Hope this may help.
Jan 20, 2010 | HP DeskJet F380 All-In-One Printer
I refilled the catridge it doesn't print
you have to clean and reset the cartridges. clean also your cartridge socket or holder.
Sep 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Epsom4050 computer keeps saying all inks are empty when they are not any ideas
Try this pull all catridges out start printer wait till it asks to install ink catridges and put back in ..Worked for me.
Aug 31, 2009 | HP LaserJet 4050n Printer
Reset ink level on hp 6310 #98 cartridge I have been using refilled cartridges and the in level is ''empty'' even when the cartridge is new and just filled. how can I reset the ink level?
if you are using a refilled catridge you would not get ink levels right.
if you want right ink level use genuine ink catridges.
you can try taking out the catridges turning off the printer and turning it back on and then reinstalling the catridges.it might not help so if possible buy hp ink catridges.
Aug 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Empty cartridge
HP Deskjet 3915 Inkjet Printer.
Empty cartidge status is related to the refilled catridges.
Please do not use any refilled cartriges in the above printer.
There is a chance of leakage of ink as a result the entire printer will not work properly.
Buy genuine HP Catridges and install the same in the printer.
If the problem still persits, please lodge a complaint with local HP office and get the cartidge is replaced with a new and genuine one.
Try to make user of Annual Maintence serice contract with local authorized ho Vendor for regular servicing of this printer.
Jul 16, 2009 | HP Deskjet 3915 InkJet Printer
Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
Jul 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
Replaced color cartiage, now only one color prints, red? Help
Try to check the level of your ink in your color catridge maybe is running low or empty then if its empty then remove the catridge then replace another color catridge full of ink then run your printer again. If you successfully installed new ink catridge then it will automatically reset the level of your ink monitor to full.
Jun 16, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
