Question about HP Pavilion ze4560us Notebook
Pavillion ze4560us Hi, I have a pavillion ze4560us and when I connect a usb device it tells me that it is not running at usb 2.0. It seems like this computer should be new enough to have usb 2.0 capability. When I check my options it says that there are no usb 2.0 devices on my computer. What can I do?
  • 152 Answers
Dude usb 2.0 was released way back... i believe the necessary drivers have not been installed... you better go to device manager and try updating the drivers... it would have option to check online... post here if u need more help...
Posted on Oct 18, 2008
My scanner won't work the printer and copier work
Scanner drivers seems to fail to communicate with printer, you have to reinstall the USB driver. Follow the steps
1. Click start ->Run.
2. In the Run window, type "devmgmt.msc" (without quotes), click OK.
3. Device Manager Window will pop out, in this screen at the bottom you will see "Universal Serial Bus Controllers"
4. Click on the(+) sign next to "Universal Serial Bus Controllers" and look for "USB Composite Device".
5. Right click on "USB Composite Device" (Read Note below and then proceed) and select Uninstall.
6. After the the device is uninstalled, disconnect the USB cable from the back of the computer.
7. Restart the computer, after the system is booted plugin the USB cable.
8. You may need to wait for sometime for the device installation to get complete.
9 . Then try to print a word document.
Note: Before uninstalling the "USB Composite Device" right click on it and select properties to confirm whether that driver is for the printer.
Regards
Riztech
Jul 16, 2010 | HP Photosmart C5180 All-In-One InkJet...
This usb device can perform faster if you connect it to a hi speed usb 2.0 port. I have an hp pivilion dv 6000, and according to the specs, I have usb 2.0, but I get this message every time I plug my flash...
This is just an error message. Yes, your HP Pavillion has USB 2.0, but there's a possibility that your USB flash drive has USB 1.1 specs.
If the flash drive has USB 1.1 specs, you would still get the same message. Again, this is just a message because USB 2.0 is backwards compatible with USB 1.1.
Have a great day!
Oct 10, 2009 | HP Pavilion dv6000z Notebook
My computer cannot detect usb my computer model is 6bxa-61 samsung
You were saying that your computer could not detect any USB devices? Or just one USB device? Alright, you need to isolate the problem, follow the steps below:
1. Use at least 3 USB devices and connect them one at a time to the USB ports of your computer. If the first USB device is not detected, mark the USB port on your computer with "X" mark.
2. Now, connect the same USB device to another USB port of the computer. If you get the same problem, use the second USB device and connect it to the computer. If all 3 USB devices are getting the same problem connecting in all the USB ports of the computer (either on the front or on the back of the computer), then you need to update or re-install the USB driver to your computer.
3. Contact the manufacturer if the computer or the board and see if they could provide a USB driver for *********** board. Tell them what operating system (OS) you are currently running.
Have a great day!
Jul 24, 2009 | Computers & Internet
Printer stopped printing and says its off line!
HI,
Im Rizwan from India, i would to tell u to check few things that will resolve this problem
SOLUTION:
NO 1: Check the Connection and power
1.Check the USB cable and the power line to the printer.
2.unplug and replug the cables at the PC an printer end.
NO 2:Check the printer status in control panel.
1.Click start - >Run.
2.In the run window type "control" (without quotes).control panel will open.
3.In the control panel, look for printers and fax and check the printer icon.
4.If printer icon says Offline, Right click on printer icon and select "use printer online"
5.Try printing, if it didnt print follow step NO 3.
NO 3:Restart the USB Composite Device.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET 720C
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Try printing Now, if it didnt work please response.
Thank you
Rizwan
rizwan84tx@gmail.com
Dec 06, 2008 | HP DeskJet 722c InkJet Printer
Usb
Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections on your phone.
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo.... 2.Select setting
  • Press Mass storage
  • Press OK. 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
    And Welcome to the Viewty Family! Enjoy...!
  • Nov 14, 2008 | LG KU990 Viewty
    Usb 2.0 on pavilion ze4560us
    This computer only has a USB1.1 support, this is the complete specs for this computer check this link http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00249077&dlc=en
    Oct 21, 2008 | HP Pavilion ze4560us Notebook
    Hi-speed USB host
    this means that you do not have a USB 2 port or do not have the USB2 drivers installed correctly if it does,
    check your chipset drivers and spec of laptop with manufacturers.
    if you do not have usb2 you can get a USB 2 PCMCIA card to supply this functionallity.
    it is possible this is a USB low power issue as this is a laptop, but check your drivers and spec first.
    Jul 05, 2008 | Sony VAIO Digital Studio PCV-RX860...
    Camera Connection
    Two things:
    1. The USB cable where it connects to the camera has to firmly in place otherwise it can disconnect from the computer even though it appears to be connected.
    2. In the HP 635 'Set up' menu there is a section called USB configuration that has a 'computer' icon and either of these two options:
    USB (Digital Camera)
    USB (Disk Drive)
    Set it to USB (Digital Camera). This tells your computer what sort of device is connect to it.
    If you are connected correctly as above this is what happens:
    1. Message: 'Establishing connection with computer'
    2. Message: 'Connected to computer'.
    3. images are copied to the computer.
    I hope this helps.
    Oct 09, 2007 | HP Photosmart 635 Digital Camera
    HP Pavilion ze4560us Notebook Logo
    131 people viewed this question
    Top HP Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
