Question about ASUS P5P800S Motherboard
The power led and reset was both on
Thats is my problem they cant open,
  • 189 Answers
We have to open the system unit where the motherboard is located, but first pull off the power of your computer so that there will be no ground.
Removed the cover, before touching any part inside the system unit (motherboard) touch first the casing or chas-is of the system unit to removed the static in our body.
Let us first remove the reset wire usually the color is red and black it has a name reset at the connection pin at the mother board usually found at the bottom of the mother board, or follow the reset botton wire found infront of your system unit.
After you have removed, try to plug the power of your computer and turn it on. We can open our computer if the reset connection is off.
That will be the first step to know the cause of the problem. Try also to clean the motherboard using vacuum cleaner the portable only or clean paint brush, cause some of those problem due to dust.
Posted on Oct 18, 2008
Standby led but cant on power
Look like malfunction AMP PCB Board.Please open top cover, unplug flex cable attached to connector AMP PCB. Try now power- ON the unit.
Jul 24, 2014 | Panasonic Home Theater System System
I have a flashing orange light and cant find the manual, I have changed the inks but its still flashing?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Dec 02, 2010 | Canon Office Equipment & Supplies
WRT610n router power led light blinks and i cant
If the power light is blinking on the router , then it might not be working properly.
You will need to press the reset button on the back side of the router for 30 seconds. release it. unplug the power cable. plug it back in. wait for a minute and check if the power light is solid.
If not then try to reset the router again.
do the same thing and check if the power light is solid.
If the power light is solid then you will need to set up the router again.
If the power light is still blinking, then connect the computer to the router and check the IP address on the computer. If the IP address is 192.168.1.100 then try to open the set up page of the router and check the settings of the router.
Click Here for step by step instructions
Dec 01, 2009 | Linksys WRT610N Wireless Router
I cant find power sw,reset sw,power led and h.d.d. led
From the manufacturer's web-site:
http://www.biostar-usa.com/app/en-us/search/search.php?search=P4VMA-M
select either the 'P4VMA-M 7.x' or the 'P4VMA-M 2.3' motherboard, and click on 'MANUAL'. Click to download and "save" the '.EXE' file to some folder on your computre. Run that '.EXE' file to create a PDF file in the same folder. Open the PDF file, and scroll-down to page 10, which has a large annotated diagram of the front-panel connectors.
Nov 20, 2009 | Biostar P4VMA-M Motherboard
I have an Asus P5VD2-VM SE motherBoard But Cant find The Leds And Switch Connectors
The Front Panel connector is in the lower right corner if you view the MB with the CPU at the top. There are 4 pins on top of the connector and 5 on the bottom. It should be labeled F_PANEL. The connections are:
(PWRLED)
Top Row first: Power LED +
Top Row second: Power LED -
(PWRBTN)
Top Row third: Power Button
Top Row fourth: Power Button Gnd.
(HDLED)
Bottom Row first: HD LED +
Bottom Row second: HD LED -
(RESET)
Bottom Row third: Reset Gnd.
Bottom Row fourth: Reset
Bottom Row fifth: No Connection
The pdf manual will not allow me to copy and paste info so I will lead you to the manual so you will have it to help solve this problem and perhaps future ones.
Go to this site:
http://support.asus.com/download/download.aspx?SLanguage=en-us
In the upper left it has a search box that says "Input Model to Search".
Type in your model number. Click on Search Info.
A verification page will come up. Click on the model number link. You will then get a small window to select your operating system. Do so. Click Search.
You will get a list of available downloads with Manual at the bottom. Click the little + next to Manual. Scroll down to the appropriate language manual. (I assume English. It is the next to last one listed.)
Click on Global (DLM) or Global or China. A download window will open. Select SAVE. Choose the folder to save it to. (My Documents will do.)
When the download is complete click OPEN FOLDER on the download window. The file should be highlighted. Double click on the file to extract the pdf file from the zip file. Once opened, SAVE it as the pdf file where you will be able to reference it in the future.
The front panel connector pinout is on page 1-35.
If you have problems, use the Comment button to reply.
Thanks for using Fixya.
Aug 24, 2009 | ASUS P5VD2-MX SE Motherboard
Cant use
Try this steps Mp150 Reset Counter
Service mode operation procedures -
button pressing
procedures below.
procedures below.
Jul 07, 2009 | Office Equipment & Supplies
My motherboard vt8235 I cant figure witch order they go
i'm guessing your talking about your power LED, HDD LED, reset button etc.? Look closely on the board, there are small hints printed on it. eg... pwr, reset, spkr etc. and on the colored wires, there ought to be printed reset, power etc. just match them and plug them in. you can't do too much damage if they are wrong.
Jan 04, 2009 | Computers & Internet
Re: the power led and reset was both on
Have you open your system unit where your motherboard is? Or you did not touch anything it just happen that.
Oct 18, 2008 | ASUS P5P800S Motherboard
Help
Check your circuit breaker. Even if it doesn't look tripped reset it anyhow. Try that first.
Nov 30, 2007 | Kenmore Elite HE4 Electric Dryer
ASUS P5P800S Motherboard Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
