LD code cycle won't start - "ld" code
  • tor427 Oct 19, 2008
    That was it - thank you!
  • Rob Curran
    Rob Curran Nov 24, 2008
    I get the LD code problem with my Kenmore washer. I've taken the back panel off and noticed clothing at the bottom of the tank, in between the tank and spinner. Is there any way to disassemble the tank to remove the blockage? ... or other suggestions?
    Also how can I get my hands on a detailed schematic of the washer. The user guide it too high level.
Yep checked my pump last night and found 2 dimes stopping the impeller on the pump.
Just tilt the washer towards the front and be sure it's supported, remove the back cover and then the short hose at the pump. Grabbed the dimes with needle nose pliers.
Done. Happy wife ...happy life!
Posted on Nov 03, 2013
  • Washing Mach... Master
  • 2,651 Answers
LD is a code for "long drain" you problably have somethin stuck in oyu pump assy ( bra underwire, baby sock, nail/screw) you l need to find the pump and remove the hoses to it remove obstruction, REAL common problem
Posted on Oct 19, 2008
try any button sequences yet . try holding start button and a cycle button hold both down to reset
Apr 01, 2013 | Whirlpool Cabrio WTW6800W Washer
My whirlpool calypso won't drain after I removed the rug particles wrapped around the drain pump fan. Showing LD code
You will need to replace the pump. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 14, 2012 | Washing Machines
Won,t spin
A LD (Long Drain) error code means that (more or less), the drain pump is failing.
May 11, 2012 | Bosch Washing Machines
I have the whirlpool Cabrio model WTW6600SB2. We keep getting the code LD when we use the normal rinse cycle. Also trying to do a clean with bleach cycle and t is supposed to go 60 mins and goes less...
The LD:
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by that fancy lectronic control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for propah pumpin.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Service Manual
More Here
Feb 03, 2011 | Washing Machines
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
Ld error code won`t drain.or do anything starts for 10 sec and stops
Owner manual - Code Ld -says the drain hose is kinked or clogged.
Check that the hose didn't get kinked when pushed back to the wall. It's a common problem. The problem is NOT the wall drain as water would be coming out onto the floor if that was the issue.
Jan 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LD model LD-14AT2 dishwasher
Are you getting an error code displayed when this was happening?
How did you fix the problem?
Aug 25, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Ld and ob codes
LD code means your pump is cloged with lint or small piece of clothing such as a sock. I had the same code on my washer and sure enough i found my pump cloged with lint from a blanket my wife washed. hope this helps. sorry I cant help on the other code.
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Washing Machines Logo
571 people viewed this question
Top Washing Machines Experts
