Question about ASUS NB | F5VL-B1 RTL PC Notebook
I try original drv for the sound but it doesnt work any suggestions Asus F5VL 1.5Ghz 2GB 160gb Hdd laptop
I try original drv for the sound but it doesnt work any suggestions.Original file name : AUDIO_XP_070416
IT says "Reboot and select proper boot device"
its asking for the boot of your windows,so if your windows is on the c,hdd then thats the one you pick.
its sounds like your laptop is not set to boot from its hdd.
so if you see boot from,a,b,or c,just pick the one that your windows are on.
May 19, 2014 | ASUS F5VL-A2 Notebook
6735b wont stay connected to internet
I suggest access device manager > network adapters>network device > properties > power management
: uncheck "allow this computer to turn off device to save power"
Is a possible workaround rather than a fix , but if it works in the interim....
Feb 16, 2014 | Compaq HP 6735B 15.4" LAPTOP AMD QL-66...
MY ASUS F5VL MOTHERBOARD WON'T TURN ON???
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
AC adapter failure.
Power jack failure.
Motherboard failure.
Possible troubleshooting steps and repair solutions:
Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Oct 30, 2012 | ASUS F5VL-A2 Notebook
Drivers for Windows 7 x64
You may be abke to get the drivers fron the ASUS WEB site.
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : -http://support.asus.com/download/download.aspx?SLanguage=en-us
Nov 24, 2011 | ASUS A7K-A1 AMD Turion 64 X2 TL60 2.0GHz...
I have ASUS Xonar DS installed on my PC (2.8GHz Pentium, 2Gb RAM, 160Gb HDD). When I try to record using Audacity or some other recording program I find that the recording seems to "miss" some...
I would check to make sure that you dont have anything else running while encoding the audio. Since audio encoding is processor intensive it very easily could be an application or AntiVirus software interfering with the ability to record audio.
Sep 12, 2011 | ASUS Xonar DS Sound Card 90YAA0F00UAN00Z
Where can i buy asus f5vl motherboard?
Buy this direct from Asus. This is the ONLY place to get one. OR eBay sometimes people sell their junked MB's when say the screen is faulty etc.
Apr 01, 2010 | ASUS F5VL-A2 Notebook
Can I increase RAM from 2gb to 3gb on an Asus F5VL and if so how, thank you
Yes you can increase your laptop memory up to 3GB because the memory limit that can handle of your laptop is 4GB. Go to any computer shop in your place and buy there a memory for your laptop. Bring your laptop so that they will handle the installation of the memory for your laptop computer.
Nov 09, 2009 | ASUS F5VL-A2 Notebook
Asus X51RL laptop, vista, xp
you can not downgrade from vista to xp on almost any computer without replacing many components...Ethernet video sound and more
Sep 05, 2009 | Computers & Internet
ASUS NB | F5VL-B1 RTL PC Notebook Logo
82 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
