Question about Maclaren Quest Sport Stroller
Maclaren quest stroller how do you remove the wheels
  • Anonymous Dec 15, 2008
    One of the back wheels has come off and I need to replace it if I can.
    Problem Solver:
  • 11 Answers
Ah! knew this one will come up, pop both the outter end cap with screwdriver (flat) -take note of all the metal or plastic washers position on the axle. see the exposed end metal rod axle and a metal washer ( called ring clip or circlip) on both side, you only need to remove circlip only one side, normally the bad, rusty one or the worst looking one! -ideally you need a special tool (£60) -but a pair of goooood plier should do it- but if you going to attempt yourself make sure you have a new set of ring clip or circlip, normally be ruin when removing them and for safety must be replaced with similar of the same specification. your new wheels set should have them! likewise your local maplin or hardware shop should stock them. Check the size of your axle 6mm 0r 8mm or etc. you might find the axle is slightly larger but the groove the clip sit in is about the 6 or 8 mm..do check! this the only thing that stop the wheel from falling out so check check check! get help.
Use your plier wedge one lip to the underside of circlip and the other on the flat side of axle...now squeezed hard so that the clip will be make it's way out. seee it's ruin the circlip. For safety do not use them again. replace them with new! and get help while putting them new circlip back on! you have to make sure when fitting new once make sure the sit tied in the groove design for it.
Caution, when the circlip is removed the axle might drop out, so that is why it is important to take some notes and drawing of all the position of washer sitting on the axle. they help to avoid friction and wearing. take a good look of the wheels position too, your pram brake lock depend on the slots on the wheels so make sure you face the exactly the way it should be.
fitting the same circlip can be a pain, position the circlip over the axle and tap them back into the groove with a small hammer. a smaller short pipe placed over the new circlip help to get it in! get help on this.
Your child safety lies in your good hands and good help, we do not want that wheel falling out when youre crossing the road. so do seek advice from expect to check for you! give it a good test and check check check pop back the both end caps when you finish!, good luck
Posted on Jan 23, 2010
SOURCE: i need replacement wheels
buy some micro scooter wheels some threaded tube, loctite, and bolts, remove old fit new job done
Posted on Aug 06, 2008
  • 91 Answers
SOURCE: maclaren quest pushchair.
Ok, I will try to do this step by step.
1. Place flat screw driver under hub cap and pry off (these we will reuse later).
2. Using diagonal pliers, cut star locks from axle, you should have received new one from Maclaren when you got the wheels, if not you will need to get those.
3.Repeat this process for each wheel.
4. Take off the old wheels and put the new ones on. Put on the new star locks (I use a small hammer), put the hub caps back on and viola, new Mac wheels.
Posted on Apr 10, 2009
  • 127 Answers
SOURCE: foam handles on the maclaren storeller is breaking off. where can I get replacments?
You can take it to the bike store and they will fix it for you.
Posted on May 28, 2009
  • 11 Answers
SOURCE: My maclaren stroller has squeaky wheels, what can
clean the wheels with soupy water, clean out all mud and things in between the wheels and hinges area. Check for loose parts, cracks and worn condition, repair and replace them if you can, let the wheels dry out then spray the hinges and any moving part and source of friction them with lubricant like W40.
SOURCE: Replacement Wheels for Maclaren Quest
where can i get wheels 4 my maclaren quest
Posted on May 07, 2010
Need to fit replacement wheels to a Maclaren Quest
Hi.
The best way to get parts for the Maclaren is contacting factory.
Please open the page below, select your region and country, and use the Customer Service> Contact link at the bottom of the page to contact Maclaren.
Here the web site.
Regards.
Ginko.
Aug 22, 2010 | Maclaren Quest Mod Stroller
Is there a way to fix a bent front wheel (only one of the two) on a maclaren quest buggy? If not, where can I get an affordable replacement?
Hi this is Sarah from Maclaren,
the folks at our customer service can point you in the right direction for a replacement wheel, or to locate a repair center you can email them at:
info@maclarenbaby.com ' ); //-->
Feb 24, 2010 | Maclaren Quest Mod Stroller
My Maclaren stroller has squeaky wheels, what can I do?
Nov 09, 2009 | Maclaren Quest Mod - Scarlet Red Umbrella...
Where is the break and how does it work please on my maclaren quest?
On your stroller, you will have an upright plastic knuckle above the wheel on both sides. Push the knuckle (on the left wheel) inwards (towards your right foot in a horizontal motion) this will lock the breaks, to unlock the break, simply reverse the procedure.
I hope this helps.
Sep 10, 2009 | Maclaren Quest sport - Placid Blue...
Maclaren quest pushchair.
Mar 23, 2009 | Maclaren Quest sport - Placid Blue...
Macl;aren quest
Just got me new wheels form ebay, click on link below!. Please check wheel diameter, unworn is about 125mm, axle size ( size of metal rod that goes through both wheel, access by removing the end cap, just pry open slowly.. measure )..should be 6mm or 8mm. using the link below buy online on ebay. under maclaren wheels or click link below
http://shop.ebay.co.uk/12459ajs/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p4340
They about £22 for set of 4 wheels normally you replace all 4 back ones! come with end clip. remove them with a good set of pliers, they can be a pain, get help! Replace with new once, get them back is easier but again if not sure ..get help! as your child is on it and you do not wanna them falling off while crossing the streets ... their safety lie in your hands now! good wheeling
Nov 24, 2008 | Maclaren Quest Sport Stroller
Aug 27, 2008 | Maclaren Quest Sport Stroller
I need replacement wheels for my maclaren quest stroller where can i purchase these from?
If you are in nyc,there's a place where you can replace it. A year ago it cost $35 a wheel to replace. You can go to the the main website of maclare to find a store near you.
hope this was helpful
Jun 25, 2008 | Maclaren Quest Mod Stroller
Maclaren Quest Sport Stroller Logo
596 people viewed this question
Top Maclaren Baby Gear Experts
Jennifer Rock
Jennifer Rock
xxxxxx xxx
Iron
Iron
Are you a Maclaren Baby Gear Expert? Answer questions, earn points and help others
