Question about Ovens
Fan assisted oven keeps going off ?
I start my fan assisted up but after around 25 mins it cuts out. After around 30 mins it comes back on again ? What is wrong ?
  • Deano70 Oct 19, 2008
    no the oven not over heaing
Suggest you look at the other things i commented on
Posted on Oct 20, 2008
    President:
  • 1,462 Answers
There is an overheat stat and this is cutting the oven off
things to check are.
is casing fan running ok? (this is the tangential fan inside the casing at the back and not the fan inside the fan oven)
this second fan is turned on by a fan stat. maybe this is faulty
is there plenty of ventilation?
is oven in fact overheating?
Posted on Oct 18, 2008
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
Prestige built in fan oven for no reason keeps tripping the fuse was working good till about a week ago
ISOLATE FROM MAINS SUPPLY BEFORE CARRYING OUT TESTS
Remove oven from unit, remove back visual inspection of wiring, this should take about 30 mins.
Several makes of ovens use heat temp control components, usually mounted on the frame or back of the oven, inspect, if there are signs of heat around the component replace. When oven is switched on is the fan blowing air when the door is open, if not very strong remove fan and clean with WD40, make sure this is dry before fitting again. If fan appears to be working correctly, a heat element could be faulty, inspact when the fan has been removed it should be mounted in front of the fan. If there is black spots, not food build up, it is more grey to black, replace the element, you should be able to get parts from white goods .co.uk. Without more info I am unable to help.
Hope this is helpful
Johnf1
May 17, 2011 | Ovens
How do I replace the bottom oven element in a CDA CD 907 double oven
ISOLATE MAINS POWER BEFORE WORKING ON THIS APPLIANCE
Remove the back of the oven check temp controller before replacing or buying element, as this can often stop any heat being produced. The element is in front of the fan, if this model is fan assisted, remove fan, after removing element inspect to see any small hole in metal, if you see a large hole more than 10mm , this could be a sign that the fan needs cleaning. Clean fan with WD40, do not switch oven on untill fan has dried off. Then replace element, switch oven on low with door open, if you feel slight heat, go for a full test, gradually build up heat, keep on for at least 30 mins, make sure the oven reaches temp, you can expect some smell from a new element, this is protective oil, and considered normal.
May 10, 2011 | Ovens
Hello, I am having trouble with my built in Zanussi ZBF 360. When I turn the oven on to the fan symbol the 'on' light comes on and when I turn to the required temperature the heating light also appears. ...
If you cannot hear the fan going, then it is possible the fan is faulty, and the element has probably failed as well.
Both these components can be accessed by removing the panel at the rear of the oven compartment
Feb 02, 2011 | Zanussi ZBF360 Electric Single Oven
Stoves efa700h grill cuts out after around 20 mins, the grill gets very hot, read a cpl of posts about fans and thermo cut outs, easy job? appreciate any help
On the 720 there are two thermal cut outs. Looking at the wiring diagram, the cooling fan and the clock are the only two items that will run independant of the cut outs. So, is the cooling fan running ok or not? If it is and the grill is cutting out, then it could be the thermal cut out that has aged - or the fan may be running slowly because of age or there is a build up of dirt grease under and around the oven and on the outlets that stop air curculating properly.
If the fan isn't running then you need to replace it or the fan timer PCB may have failed. Once you have gotten into the oven's inards, you can test the fan to see if it runs or not.
Nov 16, 2010 | Stoves 720EF Electric Double Oven
My AEG B3191-4 oven works for about 30 mins, then seems to cut out... it won't work at all until it has cooled down, and then the cycle starts again... can you tell me which part is likely to need...
Your cooling fan may not be working. either the fan is faulty or its controling device is not switching it on it also allows the fan to run on after the oven has been turned off. its located in the wiring loom behind the switches. part 899661926761-1 costs £26
Jun 08, 2010 | AEG B3101-4 Electric Single Oven
My AEG B3101-4 oven works for about 30 mins, then seems to cut out... it won't work at all until it has cooled down, and then the cycle starts again... can you tell me which part is likely to need...
It is a safety thermostat that is cutting the oven off, due to overheating.
It could be that the external cooling fan is not working, or the cut out itself is faulty.
Check to see if you can hear the fan working.
This is usually located on the top of the oven , at the rear of the oven, on the top .
Hope this helps.
Dec 13, 2009 | AEG B3101-4 Electric Single Oven
The oven turns off after 30 mins
Is the clock re-setting and flashing? Either the fan is failing and the oven is overheating, or the thermostat is faulty and the oven THINKS it is overheating. It is a fail-safe kicking in, momentarily cutting power to the oven to avoid lasting damage.
Set the time on the clock and the oven should be okay to go again, but if problem repeats, replace the fan and/or the thermostat - it is difficult even for an engineer with all his equipment to diagnose which of the two is at fault, but its about all there is to go wrong on a gas oven.
Apparently!
Jul 01, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven Over Heat
Not sure if this is relevant but, have you set the clock correctly?  The oven will cut off if it's cooking on a timer.
May 01, 2009 | Smeg SE280X Stainless Steel Electric...
Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
May 15, 2008 | Electrolux EOB5630 Ultrafan Electric...
Ovens Logo
343 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
