I have a DVP-NS575P player that has worked fine until recently. I now get a message across the display panel "CANNOT PLAY' and no other data appears on the panel.
-   I have also this fault and i replaced the spindle motor the same repeated. -   cvass2008
Mar 13, 2008
-   switched dvd player off for a few minutes and tried a new disc-   Guest
Mar 10, 2008
-   My Toshiba SD-P1600 Pportable DVD player is not spinng and I am getting a not valid disc message.-   renee3374
Mar 10, 2008
-   The disc is not spinning and I am getting a cannot read disc message. I have hardly used this machine not even a year old, only for my daugther when we go on big trips. Toshiba SD-P1600.
Thank you-   Guest
Dec 31, 2007
-   is there a fix for the disc not spinning or should I just buy a new dvd player?-   ender_wiggin
I was able to fix mine by opening the player with the DVD still inside and then I manually spun the DVD and the motor kicked in! After 2 days my DVD player is now working again! Thanks to everyone else that posted. It gave me the idea to try this.
unplug the unit overnight or 24 hours and see if that resets the microprocessor. if it dosent work then theres a mechanical problem and your gonna need to take the unit into a repairt shop unless you can take it apart first and see if theres something blocking the disc. Good luck
disc may not be spinning due to motor failure. remove top and observe is disc is spinning or not. my sony dvp-ns41p failed this way
Comments:
Feb 01, 2008
- I was able to determine that my unit was motor failure and I was ble to remove the motor and was even able to order a replacement motor online. The only problem was I needed to order 5 to meet the minimum order so now I have 4 extra. After replacing the motor it still did not run and after some probing I found that a very small surface mount fuse had blown out. (not sure how that happened) I was able to jumper accross the blown fuse with a fuse from radio shack and now I am enjoying my dvd player once more. If anyone is interested, I will post the model number for my spindle motor and I will sell of my spare motors at a reasonable price if anyone wants to try this fix
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Mar 07, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
biffo, i have the same problem and i need to buy one motor, my email is jean051174@hotmail, let me know if u wanna sell me one
Sony DVP-NS575P player won't play burned DVD with video I can play on my computer. 2 folders on DVD...
(More)
Sony DVP-NS575P player won't play burned DVD with video I can play on my computer. 2 folders on DVD VIDEO_TS and VIDEO_RM(.IFO AND .BUP FILES). Burned with windows. Windows DVD maker would not work. Does it need to be burned with something else to create a "lead out"?
My dvd player clicks really slow when you press play. And 0 comes up
with each click. At the end of the clicking something like HO2 then
says stop. What can I do to fix it?
