Question about ASUS P5P800S Motherboard
Re: the power led and reset was both on
Yeah i did not touch anything,
  • 189 Answers
Can you still open or start your computer? Even if the power led and reset are all on?
Posted on Oct 18, 2008
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
Jan 05, 2013 | AMD MicroStar MS-5191 Socket 7 mATX...
Wire diagram
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
Specifically we are talking about the Reset switch, Power On switch, HarDDrive activity LED light, and Power On LED light.
Speaker pins for an onboard speaker< (BIOS Beep Codes), may be also included in this header.
What you need is a Front Panel header pinout.
I'm looking at the motherboard now,
http://www.motherboards.org/imageview.html?i=/images/mobot/motherboards/6335.jpg
The silkscreen print next to the Front panel header, is fuzzy. Probably is on your motherboard also.
[Motherboard installed in computer case, the Front panel header is at the Bottom/Right corner. Just wanted you to know, I KNOW.
The photo has the motherboard turned 90 degrees to the Right.
PANEL is silkscreened to the Right of the Front Panel header ]
Looking at the motherboard installed in the computer case, the Front Panel header is two rows of pins.
The pins have a white rectangle silkscreened around them. To the left of these two rows of 10 pins, is another small rectangle in white.
These are for IrDA,
(6 pins. Two rows of 3 pins)
http://www.webopedia.com/TERM/I/IrDA.html
Suggest leave them alone.
There are 20 pins. Two rows of 10 pins for the Front panel header.
Willing to bet Pin 1 is the pin to the upper Left corner.
Pin 20 is the pin at the bottom Right corner.
Coming from the Left side, across the Top row;
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
Coming from the Left side, across the Bottom row;
Pins 2, 4, 6, 8, 10, 12, 14, 16, 18, and 20.
It looks as though this is just the old Front Panel header setup, used for a lot of old motherboards.
For example, I can just about make out the pins for the HDD activity LED light.
Bottom row, come from the Left side.
The first three pins, which are pins 2, 4, and 6, are for the Keylock.
DO not connect any wires to them!
The next two pins, 8 and 10 are for the HarDDRive activity LED.
Top row; Pins 5 and 7 look like they are for the Power On LED.
HOWEVER, let's use deductive reasoning based on intelligent thought.
Or in otherwords, 'Wing it'.
All you have to do, is get one of those LED lights that have two wires.
This will be your test unit.
Go across the Top row. Touch TWO pins at a time. For example Pins 1 and 3. No power? Touch pins 5 and 7. No power?
(Shouldn't be)
Touch pins 9 and 11, and so on. Keep going across the Top row.
No good? Go across the bottom row, BUT SKIP pins 2 and 4.
What will happen? When you finally touch, the two pins for the Power On switch, the LED light will light up, and the Power Supply will turn on.
With the Power Supply on you can go back, and see which two pins keep the test LED light ON. These pins will be for the Power On LED.
Test LED light blinks? You are touching the pins for the HarDDrive activity LED.
Windows is running, and you touch two pins, and Windows restarts?
You have the pins for the Reset switch.
Speaker pins will be FOUR pins in a row, and by finding the rest of the pins, you will know which ones these are.
BY using the LED light you will harm NOTHING. In fact you could use a jumper wire. If you touch the wrong pins, NOTHING will happen. If you touch the two pins for the Power On switch, the Power Supply will come on.
Shock Hazard:
The VOLTAGE is 5 Volt DC.
In comparison two D cell flashlight batteries store 3 Volts DC.
In otherwords; NONE.
For additional questions please post in a Comment.
It may be hard for you to navigate around this website, but would appreciate hearing back from you.
Perhaps you can post a Front Panel header pinout, for this motherboard, and be somebodies hero.
Just a thought.
Regards,
joecoolvette
Jun 22, 2012 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
DLink WBR-2310 freezes up with all four of the LAN ports lighted up along with the WAN LED and the power LED....the status LED and the WLAN LED are not on....router is just frozen and reset button does not...
If all lights are lit regardless of anything connected then you may have a hardware failure. Try a hard reset by putting a tip of a paperclip into the small reset hole while powered on for 10 seconds. See if that resets you router - if not then it is dead.
Nov 22, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Reset sw, power sw, and hdd led where do i put them on the motherboard
hello, your front panel connectors like reset sw, power sw, hdd led, you can search easily. a use of screw driver touch all front panel connectors, if any response of connectors connect it.
Aug 10, 2009 | MSI 745 Ultra (MS-6561-010) Motherboard
How to reset tissot t-touch after battery replace? I could not find the AC point,there is many points under the battery but not accsessible when the battery is inserted.
AC point is not located under the battery. It is at the edge of movement. Get an eyeglass with good magnification and you will find it.
Rate me, please.
Aug 06, 2009 | Tissot T-Touch T33159851 Wrist Watch
Touch pad always lit up...
Yes, if the leds are all lit and no respnse, then your board in the top counsel is faulty. Have you haad any power surges recenlty.? Power surges sometimes mess up computer boards. But yeah, it sounds like its bad tho. There should be led light on unless you start pushing buttons. Have you hit the "off" selection. If nothing turns off the led lighting, it sounds like the board might be bad...hopefully this helps
Jul 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Need front panel pin colour code
The two green cables are for power LED, one + and one -. Then there are two yellow cables for the HD LED, with one + and one -. The red ones are for ON/OFF (power button), and the blue are for reset. So yeah, you are technically right if I understood what you said xD
May 21, 2009 | EliteGroup EZ-BUDDIE (ezbuddiep4) Barebone
Problem with toshiba A135-S4527 ,MOTHERBOARD NOT INITIALIZING
Try this:
I left mine on, in its coma cond overnight. The next am I touched the enter key and it booted up! 5 days later it went back into is coma.
Yeah, Toshiba Laptops ****! My A135 S2246 is doing the same thing. You and I aren't alone either. Search for: "toshiba sucks" and you'll see how many there are, lots of them. 1 week after warranty expires it started doing exactly what yours is doing. I swapped out ram with known good ones, HDD also, I connected external monitor, keyboard, nothing changed. I re-seated the CPU, temp disconn cmos batt -no help.
Cleaned all the connectors & grounds, no help.
Observations:
Fan runs on & off, I feel heat being pushed out.
Can hear Hdd spinning, indicator led briefly flashes when I first turn on.
Fn indicator led will illuminate, sometimes.
caps lock led -not at all.
numeric keypad led, no.
the only key that seems to do anything is Fn.
Toshiba wanted $35. just to discuss it over the phone. -WRONG!
Its now two years old and about as useful as a milk bucket under a bull!
Jan 13, 2009 | Toshiba Satellite A135-S4527 Notebook
Have you open your system unit where your motherboard is? Or you did not touch anything it just happen that.
Oct 18, 2008 | ASUS P5P800S Motherboard
Htc touch
HI,
Its time to take it in for service. Touch screen needs to checked. There is nothing much you can do apart from what you have done on your own. It requires special tools to open.
I suspect the Touch screen has to be recalibrated.
Thanks
Mandeep
Jun 09, 2008 | HTC Touch P3450 Smartphone
ASUS P5P800S Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
