Question about RCA F31672ET TV
Volume goes up on its own and stays up.
I can turn the volume down but it goes right back up to full volulme on its own. No buttons seem to be stuck. I thought maybe the remote was stuck. So I took the batteries out but it still does it. I push the volume down button, but as soon as I release it, the volume goes back up to full volume on its own. Some times the volume wont go down when I push on the down button.
    President:
  • 3,130 Answers
Aren you sure that the volume up button is not stuck in . It should feel just like the rest of them A little click? It could still be shorted,or the capacitor across the switch could be defective. If all this seems good then the eeprom, or the microprocessor,or the line or trace going to the volum button could be shorted. This is not a repair you should attempt unless your a tech. Now the button thong can be looked at after the set is unpluged and the back is off, gently slide out the chassis toward the rear of the set just a little and slide it back to see if the button is released. if that dosent help then you will need to take the set to The repair center. Good Luck
Posted on Jun 10, 2006
My volume display stays on
The Tv needs to be serviced by a technician.Probably there is a problem with the circuits inside.
Apr 12, 2008 | Televison & Video
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
  1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
  2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
  3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
  4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
  5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
  6. Use the volume buttons to move up and down through selection in this menu.
  7. Using the volume down button, scroll down to "Wipe data/factory reset"
  8. Tap Power hard key to select option.
  9. Scroll down to select "Yes, delete all user data".
  10. Tap the power button to select. Wiping and formatting data will take a few minutes.
  11. You will return back to the Android recovery screen menu.
  12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Dec 31, 2014 | Tablets & eReaders
No volume without holding remote button
The volume on either on your Remote or Tv is stuck down. This can be caused by spilling Liquid onto the remote (we all do it) you can test which one it is.
take the battery's out of the remote and turn the volume up via the Tv volume button on the telly. If this stays at the required Volume Then this means that the - volume button is stuck down on the remote. Try and clean it with something like a baby wipe or something similar (not a sopping wet cloth) If this does not work then you may need a new remote.
Hope this Helps
Cheers
Little Dish Fitter
Sep 24, 2009 | Televison & Video
Aiwa CXZL 31 volume button seems stuck
all u have to do is turn the volume down once then bang it against the door 5 times...it should be fine...
Jan 04, 2009 | Aiwa Audio Players & Recorders
Works, but goes into protect when you turn up/down volume
If its new call Sony and get service????????????
Aug 28, 2008 | Sony STR-DE445 Receiver
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Volume starts out at full
If you read the owners manual careful it tells you something about setting the volume at start up buy setting the volume to desired level then push in and hold a few seonds the volume knob and that volume should be reached every time you start your vehicle.
Oct 12, 2007 | Dual XDVD8181 Car Video Player
Controls
Someone push the volume up button too hard and is stuck,this also has the micro(brain) confused,all this happen before you fund out your remote would not work.
Sep 03, 2006 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Televison & Video Logo
374 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
