Question about Canon ZR200 Mini DV Digital Camcorder
Gray Lines I have a Canon ZR200 its a digital camcorder, when i go to record the screen displays gray lines across the screen. Its only when i go to record or view previous recording. Some one told me to get a cleaner tape but it did not work. Can you help me?
  • 8 more comments
  • lydiadonelle Nov 02, 2007
    This problem is exactly what we are experiencing. The digitally recorded items are fine with no lines on the small screen or the TV via the cables. When tapes that were prerecorded (and viewed in good condition before) are put in to play both the small screen and the view transferred to the TV screen through the cables have thick horizontal lines evenly spaced down the screen. The speech is slightly distorted every few seconds and at the same time the pictures slightly distorts and pauses as well.
    Any suggestions?
  • mcpmvk Nov 22, 2007
    ZR200. While recording, everything seems fine. When play back or watch on TV, five evenly spaced thick grey lines appear with some voice disturbance. Tried head cleaner minidv dry tape with no luck. Tried remove and reinstalling battery - no help. Any idea?
  • skoyck64 Dec 13, 2007
    I just started having this same problem out of the blue. Has anyone called Canon? First when you tried to play back a tape it wouldn't play anything. Then I fast forwarded and then rewound and it started playing with the gray lines. Thought it might be a dirty head but from reading here it seems cleaning the heads is not the solution. Any ideas on a fix?
  • xternal Jan 02, 2008
    I have the same problem and my camera is fairly new. I spent a good chunk of money on this camera and what do I get? I get a playback mode that have gray lines and no pictures. I am going to call canon but I am glad to hear I'm not the only one have the same problem. Maybe we can get a rebate since this is such a common problem. We have to get together on this one guys. Well I will post a update if I hear from Canon anytime soon.
  • Dazza1011 Jan 26, 2008
    Have just experienced the same problem with MV800i. Originally viewed the tapes thru viewfinder and transferred onto PC...all OK. Discoveredthat I had not transferred all video, so inserted tape back into camcorder only to discover thick grey lines across the viewfinder screen and also visible on PC. Audio slightly distorted also. The remaining video was of a recent trip overseas, so this is all the footage we have. ANy help would be greatly appreciated. I also inserted another 2 tapes that we used (that transferredto PC earlier OK0, and they now have grey lines also !! Must be a camcorder issue.
    PLEASE HELP !!
  • karenec Feb 21, 2008
    Same problem - screen looks fine but in playback, they are thick gray horizontal lines across the screen. I also put in tapes I had previously viewed that were fine and had the same problem. Am calling Canon now and will update once I talk to them . . .
  • Amadsen Apr 10, 2008
    I am yet another owner having the same problems. At one point I had grey bars across the screen and they didn't appear when I downloaded to my computer. After some more use the screen went completely grey. I purchased a head cleaner, used it once, and my camera worked like new. After one hour of recording it went back to the grey lines, only this time they appeared on my computer, in the view finder, and on the LCD. I tried several different tapes and cleaned the head again - no luck. I talked to Cannon about the issue an they had no resolution and requested me to send the camera in and pay a minimum of $175 to look at it. Frustrating. If anyone else has luck with Cannon, please post.
  • Nikkikix Apr 19, 2008
    I also have been having this problem with my canon, it's not that old and I have lots of priceless video that I have not been able to transfer to dvd yet. I would like a solution!
  • Anonymous Apr 21, 2008
    I have the same problem. I've had this problem twice before.....sent it to Canon to be fixed.....it stays fixed for awhile, not it is doing the same thing again! Last time on my receipt they said they had fixed the "mechanical Chassis"....but apparently they didn't do a very good job at it! I don't use the camcorder that often.....maybe fill up a 60 minute tape every 3-4 months. So, so, so frustrating! I guess I'll be contacting Canon again!
    Lori
    Utah
  • jluns2 Sep 18, 2008
    I have had the same problem along with the tape not loading problem. 1 good smack corrected the tape loading problem and for now another good smack also corrected the gray line problem. Hopefully it will at least stay corrected long enough for me to be able to transfer all my tapes to my computer and then throw this camera in the trash and not give me any more heartburn.
My ZR200 has been doing the same thing for the past year and a half. I have not called Cannon yet, but i did notice that whenever I charge the camcorder next to the TV the lines often return. My unoffical thought is that the magnetic field that surrounds componets such as a TV may be disrupting something in the field of the camcorder when itis so close. Do not take this as the gospel, it is something I will be continue to monitor. But mine always starts working after I move it from the perch by the TV. Just a thought.
Posted on Oct 09, 2008
Same issue
Posted on Aug 20, 2008
My post was from Jan 26. Sent my Canon MV800i into Canon directly under warranty for repairs (after being told by local distributor that the head was gone). Also previously tried head cleaner but made no difference. The camera came back 2 weeks later fixed, but the report said there was no fault found ! Still no closer to finding out what caused it...just hope it doesn't happen again.
Posted on Jun 24, 2008
I had the same problem twice with my ZR80. The first time Canon fixed free of charge since it was in warranty. It worked for 3 years, and I just had problem again. I sent it to Canon and they wanted $180 to fix... I called Canon and asked for a manager and told him that I read about a recall on it in 2005, they are fixing it for free now. Check out information about recall in october 2005.
Posted on Jun 23, 2008
  • 513 Answers
What do you mean by "Its only when i go to record or view previous recording"? in what situation doesn't it show the gray lines? What about the viewfinder? do you get lines there aswell? If you don't see the gray lines when you transfer the video out of the camera, then you don't have a head problem, a screen problem maybe. Don't hurry to use cleaner tapes because they can hurt the head, the actual cleaning procedure is one that scrapes the head and leaves some damage. more info please
Posted on Jun 12, 2006
I have gray lines on my Canon video camera display - on tape and playback. It happens on playback to the TV as well. Other tapes have it on display also. Thoughts?
Its sign of clogged/ dirty video head in your camcorder, put Video Head Cleaning tape in camcorder to clean video heads, problem will be solved.
MiniDV Video Head Cleaning Tape is available in stores.
Thanks.
Dec 04, 2009 | Canon ZR200 Mini DV Digital Camcorder
Grey Lines across video display
Same thing is happening to mine, it's not the minidv because i tried that one on a diffrent camera and it works fine. It's got to be a setting or something. If anyone can figure it out, that would be great.
Sep 01, 2009 | Canon ZR200 Mini DV Digital Camcorder
Grey lines across video display
pls rate me WELL if i have helped u !
Regards
Zohail
May 20, 2009 | Canon ZR200 Mini DV Digital Camcorder
Gray Stripes displayed when playing video
I am having the same problem with a Sony Digital 8, When I hit play I see blue screen buy when I press play and fast foward I see the same gray scan lines> Did you have a stuck tape or problems ejecting tape? I think it is more than cleaning the heads. When I try to record it indicates no tape in camera.
Apr 25, 2009 | Canon DC210 DVD Camcorder
Gray lines across screen
You have a "head clog" more than likely...accordianman
Jun 10, 2008 | Canon ZR200 Mini DV Digital Camcorder
Grey lines across the screen
Does this happen on all dvs tapes? If so then it is a problem with the head reader of the cam, but if only one tape, then that tape is either has quite an old recording on it or the tape is damaged.
Jan 12, 2008 | Canon ZR200 Mini DV Digital Camcorder
Gray lines across video screen during playback
my canon zr 200 in playback is fine but when i turn it on to record i have multi colored bars on screen and wont record
Jan 06, 2008 | Canon ZR200 Mini DV Digital Camcorder
On playback, the video has gray lines across it
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. The person who helped me solve this said: "the speed isn't linked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that."
My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Dec 28, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Canon zr200 Gray lines
Change your resolution and it should go away.
Dec 17, 2007 | Canon ZR200 Mini DV Digital Camcorder
Horizontal lines on playback screen
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Nov 15, 2007 | Canon ZR100 Mini DV Digital Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
598 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
