Question about Frigidaire Washing Machines
I have a dr error code what does this mean - Frigidaire Washing Machines
Did you try checking the thermestat?
Posted on Oct 20, 2008
What does a SC error code mean on my Samsung front loader with dr in dr
I think that SC = Spin Cycle. Could the machine be overloaded? Take some of the heavier items out and try again.
Jan 23, 2018 | Samsung Washing Machines
Wtat is the dr code error?
Hello Aung, I appreciate your post!
Based off what you have described your Electrolux washer is displaying an error code of "DR". The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. You should perform a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Dec 30, 2015 | Electrolux Washing Machines
I have a Frigidaire front loader washer model number LTF7000EGO and it was washing fine then started a beeping noise with dr flashing. What does that mean?
Hello friend, thank you for your post!
I understand that your Frigidaire washer, LTF7000EG0, is displaying a "DR" error code. "DR" stands for door which means a problem with your door it could be an issue with the door latch assembly or door strike. I would suggest resetting your washer and you can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes.
If you continue to experience an issue with the error code "DR" I would recommend reaching out to a professional technician for proper diagnosis and repair. I hope this information has been helpful. -Matt
Oct 09, 2014 | Washing Machines
Error Code "dr"
Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Error code DR
dr is a door error your door is not closing or your door lock is faulty
hope it helps
Aug 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Error code
'dr' is an error code that indicates the door is not closed. If closing properly the door lock may have to be replaced.
Jun 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
It means the door isn't shut all of the way.
Aug 17, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
