Kirland Washer Agitator Problem (Whirlpool)
The agitator in the washer now moves only intermittently. When the washer is running you can even spin it with your hand and only occasionally feel a "push" against the agitator by the machine. What are the possible solutions and how can the agitator be remove for inspection?
  • Aburro Oct 19, 2008
    You were completely correct. I purchased an Agitator repair kit and installed the parts and the problem was solved. Thanks!
    Scholar:
  • 112 Answers
You have what are called "dogs" inside the agitator which are plastic gears. They commonly go bad and are easy to change. Just pull the top cap off of the agitator. Then look down into the center cavity and you should see a round plastic cap. Pull up on this and remove it. (note: it has an o-ring which often tears and needs to be replaced.). Once this cap is off, there will be one center bolt that you remove and the top agitator will come off. You will see the 4 plastic dogs when you remove the assembly.
Posted on Oct 18, 2008
Slow spinning agitator with knocking sound
agitator dogs. take them out and replace.
Feb 28, 2009 | Whirlpool Washing Machines
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
Agitator not engaging
it will spin freely try to move it back and forth in full spins. if it spins both ways you need to replace the agitator dogs
Jan 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Won't agitate!
does your model have a drive coupling its between the motor and gearcase,when they brake the machine wont wash or spin and makes a wierd noise
Jan 12, 2008 | Whirlpool LSR6232J Top Load Washer
Whirlpool Ultimate care ll Quiet wash Model # LSQ9564SQ0
The ***** part of the agitator is supposed to ratchet in the clockwise direction. this is normal. If you can spin it in either direction (turned off) then you need a set of agitator dogs.
Jan 10, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Washer LSR8233EQO
either motor faulty or if mtor is running then the flexibla coupling between the gearbox and the motor is faulty. Regards Advisor
Aug 22, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Top Washing Machines Experts
