Question about GE Advantium 120 Convection/Microwave Oven
Door latch broke
How do you replace the door latch ?/
  • GE Master
  • 9,098 Answers
Normallyyou have to separate the door panels (as shown in the attached photo)and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If this answer isn't close enough for you, or your model is not shown, please reply back with your brand and model number so we can help you better.
Posted on Oct 20, 2008
The door latch broke
Slightly different model, but this will help you fix it.
https://m.youtube.com/watch?v=JqeeGBhRwFw
Feb 06, 2016 | Samsung SMH2117S
The 2 hooks(latch) inside the door have lost spring tension.
For no apparent reason, the latch broke on the 9187 ST. Take the door off of the microwave,which isn't too hard. Rotate the door to 90 degrees, lift up, and slide it to the left. Place the door on the counter, latch side up. Use a thin knife or screwdriver to lift the panel that covers the latch. It is very easy to remove it from the door. Then slide the latch up and lift is out. The spring is under the latch. The clip on the latch that held the spring was fractured. So, I drilled a tiny hole in the body piece from where the clip extended. I reattached the spring to the latch, replaced the panel, replaced the door, and it is as good as new.
Nov 11, 2012 | Samsung SMH9187ST Microwave Oven
I have a door latch on my whirlpool microwave that has broke several times. We have glued it back several times due to I am a cheap *** and don't want to buy the whole door. Well luckily my dad lo
Please Heidi,
FOR SAFETY REASONS...
It is vital that you have all covers in place and the MICROWAVE fully contained at all times when operating.
You have a high frequency radio there...
It is best to always have a substantial amount (like a cup of water) to absorb the energy...
The best thing that can happen with the energy... it will turn back on the magnetron (source) and COOK ITSELF...
The worst... you will be feeling your own
eyeballs getting WARM.
BE SAFE (please).
Carnac the Magnificent
Apr 25, 2017 | Microwave Ovens
The locker (latch) on my microwave broke. We just got the replacement part in the mail. Sears says we should be able to replace it ourselves. I see no screws to get inside the door. Does the plastic flange...
If there are no screws to hold the inside door cover in place then they are probably using snap or lock in tabs around the edges to hold it
in place. You will have to disassemble the door to replace the door latch. ----------
Its a latch spring assembly.-------- Click this link below and follow the door lock latch replacing procedure:---- http://technoanswers.blogspot.com/2011/07/how-to-replace-door-lock-latch-on.html ------------------- This will help.Thanks.Helpmech.
Jul 14, 2011 | Microwave Ovens
Inner Bootom Door Hinge Broke off...since then it will not turn on...Will that prevent microwave from functioning?
You probably mean the door LATCH broke off. Yes, that will prevent your oven from operating. The door latches operate switches inside to indicate that the door is closed. If the control board doesn't see the right switch settings, it thinks the door is open and won't allow cooking. Replacement latches are available, but you should check with a professional shop to do the repair. If door repairs aren't done correctly, there is a chance of microwave leakage and an unsafe oven.
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Door latch broke.
Part is available,
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JE1640WA01&productCategoryId=0123245&brandId=0432&modelName=MICROWAVE&diagramPageId=00001&documentId=E2134524&pop=flush
Eric
Nov 21, 2009 | GE JE1640WA/GA Microwave Oven
The door latch broke, and I can't get the door open, or the food that was in there before the latch broke!!!
Remove the cover --- you shuld be able to release the lock from withinthe cabinet.
While you are there, you may want to replace the door safety interlock switch(s)
You may have to disassemble the door to get the latch fixed.
Oct 19, 2009 | Microwave Ovens
Upper door latch needs replacing
entire dooor replacement is best course here. even if the part is availaable seperatly, youll need to order afewdifferent parts that you will break to get into as well as the extra labor to remove and reinstall the parts, the complete door ( if available and cost prohibting) is usually best course of action
Mar 20, 2009 | Panasonic Microwave Ovens
The door will not latch
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Aug 31, 2007 | Sharp R-1480 Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
48 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
