Question about E-Machines eMachines Desktop PC
Windows xp desktop boot problem
I have to boot several times to get pc on. makes a clicking noise some times. black and white screen appears with disk and all kinds of disc information. after i finally get it on works fine for a while, but gives trouble coming out of hiberation.
You have a hard drive that is coming to the end of it's life. The clicking noise is an indication of impending mechanical failure. The reason your pc must be rebooted several times is that it is now taking longer and longer for the hard drive to get up to speed so that the pc will recognize and attempt to read from it. BACK UP YOUR IMPORTANT FILES NOW. The black and white screen you are seeing is the boot up information that every pc goes through at start up. Manufacturers have taken to hiding this information with graphics but it is still there. If you built your machine from scratch then the infomration is not hidden from view and stays on the screen while the pc waits for the hard disk. It eventually gives up. Please take action TODAY to replace the hard drive before you lose the ability to access your files.
Posted on Oct 18, 2008
    Sergeant:
  • 352 Answers
Hi utility,
Try this, it may work for you. What I’m going to suggest is entering the DOS environment and making necessary changes to get your pc up and running.
- Reboot> At reboot watch for DOS screen option “enter setup” via a F button option. You have to watch closely because on some pc’s this option goes by quick, so be ready to act. Once in the DOS environment navigate to “boot options” choose safe mode . Save changes and exit. When your os is up go immediately to system restore: Click Start>all programs>accessories>system tools>system restore. Choose a date before your issue arose.>click next/continue and wait for system to restore. Reboot, and enter DOS environment once more and go to boot options and choose “Normal boot”>save changes and exit and you should be done. I hope this helped or at least gave you some ideas for further investigation.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
My sansui pc/tv monitor isn't working properly when I connect it to my desktop.
Windows is likely crashing while loading recently upgraded device drivers. The most common culprits for this scenario are video drivers.
The next time you boot, as soon as you see the Dell splash screen, start tapping the F8-key about once every second until you see a white on black menu. If you see the Windows logo, you missed it (try again, this time start tapping the F8-key a little before the Dell splash screen).
This menu will allow you to boot Windows in "Safe Mode", which will bypass any non-essential drivers and applications that could be causing the crashing. Select "Safe Mode with networking".
Assuming the computer booted fine in Safe Mode, you will be able to remove the troublesome drivers. You will see an informational message about Safe Mode, which you may close at any time. Right-click "My Computer" and select "Manage". Wait a moment for the Computer Management window to appear. Then, click on "Device Manager". If Windows was able to identify the faulty driver, it will appear in the list with a bright-yellow triangle. If this is the case, right-click and "uninstall" it. If it did not show up, first click the tiny white triangle next to "Display Adapters" and "Monitors" to open those categories. Then, right-click and "uninstall" everything listed within the two categories. Your computer will probably boot normally after doing this. But, try and find the proper driver for you video adapter before rebooting if possible. I recommend also re-installing the chipset drivers which may be related to the problem.
To attain drivers for your specific Dimension B110, visit the following link and enter the service tag code on the back or side of your machine: Dell Drivers
Oct 28, 2012 | Sansui HDLCD1912 19in LCD HDTV 720p
Hp touchsmart wont boot past start up screen
Try running the Check Disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Jun 09, 2012 | HP Touchsmart IQ524 PC Desktop
It went to welcome screen and after i typed in my password, got a black screen that says insert disk and press F1 or press F2 and something about setup.
This happens whenever one closes any installation prematurely. Insert the disk then properly cancel or complete the setup and restart the computer you wont get this message.
Jun 22, 2010 | Dell Dimension 2350 PC Desktop
How to reinstall windows xp if files are missing??
actually you can reinstall your xp system but this you can't, why:
the reason
your windows xp system are being updated every month...
the version from original system are being extracted to a new version....
by this time reformat you hard disk...
Jun 18, 2009 | Gateway 310 Series (158920) PC Desktop
Won't start completely
You have a virus I hope you have your data backed up. Reformat your hard drive(I assume you have a boot disk)
Dec 25, 2008 | Microsoft Windows XP Professional for PC
I have a ViewSonic flat screen monitor. The images on the sign in page are fuzzy and unreadable. I have Windows XP.
I would check the connections between the monitor and computer. Also the refresh rate and/or resolution might be wrong. To correct this, you will need to boot your computer in safe mode. (restart computer, right after the computer's logo appears rapidly press the F8 key until a black and white menu appears. Select SAFE MODE) once the computer boots to safe mode, the sign on screen will appear very large. Sign onto the computer once at the desktop, RIGHT CLICK the background and select PROPERTIES. Once the display properties window appears click on the last tab SETTINGS. Here is where you can adjust the resolution. Take the screen resoltution to a low setting. You can always change this later when you boot your computer normally to get a better view. Next click on the ADVANCED button click on the MONITOR tab, usually flat screens operate at a lower refresh rate then CRT monitors. I usually keep my refresh rate to 60 Hertz. Next click on the GENERAL tab. This will allow you to change the DPI setting. I usually keep mine set to 96 DPI. You may want to experiment with this as monitors vary. Once done, click on the APPLY button then OK. Restart the comptuer and see if this has improved your display. You may need to do this several times trying different settings until you get a clear display. If you've exhausted all these steps, try a different monitor or changing the cable. If that fixes the problem then you know you have a bad monitor or cable. Good luck, let me know how it turns out.
Dec 19, 2008 | Computers & Internet
Screen Wiggles, CPU Shuts Self Off, Powers Up Very Slowly
Hmm... Any errors on the screen?
Could be a power supply. Fluctuations in that can cause power drops, which would be visible in the video card, and if severe enough, cause the PC to shut off. There are 4 screws and one 1 wire holding those in. It would take about 10 minutes to replace and probably cost you $40-$50 in parts.
To have Geeks do it: Probably $100.
Dec 06, 2008 | Dell OptiPlex GX280 PC Desktop
Windows wont load
is your computer set to boot from cd?
Jun 01, 2008 | Computers & Internet
Reformatting pc
what you need to do is put the XP cd in the cd or dvd drive first,then, when the pc is booting up press either F2 or Del depending on bios and the cmos setting screen will appear. Go to advanced cmos settings and the top line normal reads 'first boot device, this will be set at HDD or hard disk, this needs to be changed to cdrom. When you have changed it, save settings and exit, the system will now reboot and an option to boot from cd screen will appear, you then press Enter to boot from cd then follow the instructions to format or install windows.
Aug 27, 2007 | Dell Dimension 4600 PC Desktop
E-Machines eMachines Desktop PC Logo
71 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
