Question about Toshiba 32A62 32" TV
Picture this tv has worked very well , but just reacently afer you watch it for a half hour to a hour the picture slowly dims and turns black . Now if you shut it off for a few seconds it is fine again for the same time frame. Is thier some sort of reset buton ? Man that would be nice any easy buton lol.
    President:
  • 3,130 Answers
LMAO. Man I wish things were that easy! An easy Button ?? HHMMM lol no Im afraid you probably have cold solder connections on the filiment connections on the CRT (picture tube) board or in the filiment circuit. It could be a video problem as well but the only way to tell would be with a multi meter . Now if your not a tech, it wouldnt be wish to open this set as theres very high voltage inside the set. seek a pro to assit in this repair. Good Luck
Posted on Jun 10, 2006
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
Plasma TV has a black uneven splotch in the middle of the screen
hmmm. sounds like the screen might be damaged. You might have to get a new one. But before you do that I would try leaving it off for a while maybe a few hours or so and see if that helps.
Jul 10, 2017 | Televison & Video
HOW CAN I FIX MY ELEMENT SCREEN
If the audio still works then the inverter would be the most likliest cause. You can get the inverter board from www.tvrepairworld.com
Aug 12, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Panasonic TV slow to turn on, works fine after it turns on.
If you have to try to turn it on several times it is power supply related.
If dirty inside on fans etc it would cause set to shut down(the set monitors the fans for speed)>
I would suggest (take it outside) using a air compressor and cleaning the entire set out.
Lamps do fail---average life is 2000 hours for a original lamp and much less for a generic one.
If picture comes up try to watch the light from the lamp---if dim at first and then slowly comes up---it could be the lamp or the ballast the set uses to power the lamp.
Jun 10, 2012 | Panasonic Televison & Video
How to clean Mitsubishi TV WD-52327 fliter
Remove the 2 screws in the access panel on the left rear side of the tv. You will see the filter behind it. Rinse the filter in warm water until clean. Lay it flat on a paper towel and fold the other half of the paper towel over it. Press gently on the towel to soak up most of the water, and install it in the tv.
Oct 10, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Picture faded to black, came back, faded again and had stayed black.
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Oct 11, 2006 | Mitsubishi CS-40507 40" TV
Toshiba 32A62 32" TV Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
