Question about Lexmark Office Equipment & Supplies
When i go to print my page gets stuck in the printer
  • alineschmidt Oct 19, 2008
    thank-you for your help.We had to buy a new machine
    Scholar:
  • 77 Answers
Open the back door of the printer and see if you can clear out any jammed or stuck pieces of paper and retry. this usually works unless there is a mechanical failure in which case you get to buy a new machine :)
Keshy
Posted on Oct 18, 2008
Konica minolta pagepro 1350w not feeding full page but get stuck at half page.
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
Feb 16, 2014 | Konica Minolta PagePro 1350W Laser Printer
HP 2200LaserJet prints a few pages, then gets stuck
You may have a recurrent paper jam. Use a strong light to examine the entire paper path. Even a tiny fragment of paper can cause the problem you describe
Jan 27, 2013 | HP LaserJet 2200D Printer
How do i get printer working
Are you able to print test page from Printer ?
This will help us diagnose and isolate the issue further
To print self test page ( Demo page ), do these steps below
Press the right arrow button simultaneously. It should start printing the demo page.
If this works fine, this could possibly be an issue related to print jobs stuck in queue.
To clear print job stuck in Queue
Click on Start button
Click on Control panel
Click on Printers and Faxes
Check for HP Laserjet Printer icon
Right click on the printer icon and Click Cancel all documents
Once you have done the above step, disconnect the printer from PC ( if using usb ) or turn printer off
Restart your PC/laptop
Check under printers and faxes folder if the Printer status shows Ready and 0
You are ready to print
Nov 02, 2010 | HP Color LaserJet 2600n Printer
Test page prints each time it's turned on
Test pages are often printed by holding down one of the buttons on the printer. Make sure that none of the buttons are stuck. Look up in your printer manual which button is for test print and make sure it isn't stuck.
Aug 15, 2009 | HP PSC 1410 All-In-One InkJet Printer
After printing first page, the second page gets folded as envelope
Hello sir; It seems like registration roller clutch defect, replace it!
May 06, 2009 | Konica Minolta PagePro 1350W Laser Printer
Paper stuck
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Konica Minolta magicolor 2300DL Laser...
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Paper does not come all the way through the printer
This is more of a workaround than a fix: I open up the front door and use the Face-Down Tray to collect all my printouts.
Aug 09, 2006 | NEC SuperScript 860 Laser Printer
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
