Question about ASUS P5P800S Motherboard
Re: the power led and reset was both on
But its all correct position actually when i power again my computer that it happen the power led and reset will both on..
  • 189 Answers
Have you open your system unit where your motherboard is? Or you did not touch anything it just happen that.
Posted on Oct 18, 2008
The front of your computer is the Front Panel
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
What you are asking for is a Front Panel header pinout.
I do not have the exact Front Panel header pinout, for your motherboard.
Tell you what I do have though..........
Looking at the Front Panel header on the Ebay link, for the Winfast 760m02-GX-6LRS; the Front Panel header looks to be below the CMOS battery, and close to the Bottom edge of the motherboard.
(Motherboard installed in computer case)
Black rectangular strip of plastic, with contact pins sticking up.
Also looks to be a GENERAL set-up for all Winfast motherboards.
(COULD be wrong here)
This is what I am referencing off of,
Go to the third photo down. Here you see the Front Panel wires, connected to the Front Panel header; on the motherboard.
(Below round CMOS battery)
Note that the contact pin on the Bottom row, and all the way to the Right; is NOT being used.
(I'm using a 26 inch HDTV as my primary monitor, so it may be easier for me to see)
Now look at this Front Panel header pinout, for another Winfast motherboard,
(Scroll down a little)
PWRLED is for the Power On LED (Light)
PWRSW stands for Power On switch
HD-LED stands for the HarDDrive activity LED (Light)
RESET stands for a Reset switch, IF USED.
Note where it has a Positive ( + ) sign, next to the pin for the PWRLED.
This is the pin the + wire from the Power On LED connects to.
It is the SAME for every LED that connects to the Front Panel header.
Let's number the contact pins, to make the explanation easier;
Starting at the Left side, Top row; going towards the Right;
Pins 2, 4, 6 and 8. There is NO Pin 10.
Starting on the Left side, Bottom row; going towards the Right;
Pins 1, 3, 5, 7, and 9.
Pin 2 is for the Positive wire.
Pin 1 is for the Positive wire
If the LED's are dim, (PWRLED, and HDD LED), OR; the LED's do not light up, switch the wires around.
(Pin 9 is N/C.........Not Connected. This is probably a 5 Volt test point, that was used by the factory)
There is a method you can use though, and find out what the individual contact pins are, in the Front Panel header;
Use an LED with two wires
Computer (Power Supply) plugged into power, go along the top row, and touch two pins at a time, with the two wires of the LED.
Example; Pins 2 and 4, as shown in the pinout.
Did the Power Supply come on?
Go to the next two pins. Try again.
When the Power Supply comes on, you naturally know that is the two contact pins; for the Power On switch.
DO NOT touch them again. In fact connect the Power On switch wires.
Power Supply on, computer running;
Now go back along again;
1) LED light blinks?
You have the HarDDrive activity LED, contact pins.
2) LED light stays on?
You have the Power On LED, contact pins.
3) Computer restarts?
Those are the Reset switch, contact pins.
4) Nothing happens?
May be contact pins for a speaker, or contact pins that are not used.
(Speaker is for hearing BIOS Beep Codes.
You have a Piezo buzzer, to the Left of the CMOS battery; for that)
Post back in a Comment, as to the results.
If possible, I would like to ask upon you; to post the Front Panel header pinout; when you find what it is.
That way when a person in the future also has this same problem; the solution will be posted on the internet, for them to find.
For additional questions please post in a Comment.
Apr 30, 2013 | Leadtek Winfast 760m02-gx-6lrs Socket 754...
Foxconn - 915P7AC-8KS i dont kbow where to put the
Do Not know if this correct. What will happen if I'm wrong? We'll start over, and we will use a basic method;
Looking at the motherboard installed in the computer;
The Processor is to the Top, Ram Memory slots to the Right, (Yellow, and Blue), white long PCI slots to the Bottom.
To the right of the white PCI slots are 4 Red SATA connectors.
To the right of them is the black rectangular Front Panel header.
[ The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front panel header ]
There are two columns of contact pins.
On the Left side is NO pin, and then 4 pins.
On the Right side are 5 pins.
Pins on the Left side are numbered ODD.
Pins on the Right side are numbered EVEN.
Starting on the Left side, coming Down from the Top;
NO pin, pin 3, pin 5, pin 7, and pin 9.
Starting on the Right side, coming Down from the Top;
Pin 2, pin 4, pin 6, pin 8, and pin 10.
A) Pins 3 and 5 are used for the Power On switch.
B) Pins 7 and 9 are used for the Power On LED (Light)
Pin 7 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
C) Pin 2 is N/C. Not Connected
D) Pins 4 and 6 are for a Reset switch, IF a Reset switch is used.
E) Pins 8 and 10 are for the HarDDrive activity LED. (Light)
Pin 8 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
Jul 28, 2012 | Computers & Internet
I need to know the correct placement for the power on leads to the motherboard on the emachine c2782 Thank you.
Use a magnifying glass to read the mobo print by the wire connectors. You should be able to spot something.
The on/off (power) button will go to the connector marked PWR or PW_SW or similar.
The LEDS will be (you should have 2 at least), one going to power led which should be named something like POWER, PWR_LED or PW_LED. And the other should be something like HD_LED or similar.
You might have to follow the wire from the case's front bezel if it's purpose isn't marked on it's connector, to figure which LED is hard drive and power.
You might have a reset switch on that case, and that would go to RES_SW or RESET or similar. LED's will not work if attached backwards. You need to connect the positive lead from the case to the positive pin on the motherboard, and the same with the negative. Unfortunately, the case connector almost never has the positive and negative labeled. The +/- is also hard to spot on the mobo. Fortunately, attaching them backwards will usually not cause any damage; the LED just won't work.
The LED will usually have the colored wires (blue, green, yellow, red, orange) as the positive, and a 2nd black or white wire which will be the negative. NOT always though. The reset switch has no polarity, so that won't matter which way it's connected. After you get it right, make a map of the pin connections and sock it away in case you need to remove/replace the mobo again in the future. I got a map of each of my computers, as they are all different (mobo's), though the cases are the same brand.
Jan 21, 2011 | E-Machines C2782 PC Desktop
One day, when i clean my system box that i take out the pannel wires from the board .these are power led,hd led etc....after that when i set up those wire i can not use my computer computer .my destop...
Hello aunglina6
As i can see from the picture of your motherboard the connections are at the bottom close to the battery. it looks like this
o o o o 1 2 3 4
o o o o o 5 6 7 8 9
this is just to give you the idea how it is set up.
9 is no connection
8 + 7 is reset switch, 6 + 5 is hard disk LED with 5 the positive of + side.
1 + 2 is power LED with 1 the positive or + side, 3 + 4 is the power switch.
with the reset and the power switch don't worry about the positive or + side. it makes no difference.
good luck.
please leave comment if this was helpful
Jan 01, 2011 | ECS RS400-A (V1.0) Motherboard
How do you rest the bios on a ASUS p4vp-mx mother board
it has a coms jumper in side coms battery 1-2 jumper normal position 2-3 clear coms choice 2-3 then *********** board reset
Nov 22, 2009 | ASUS P4VP-MX Motherboard
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Power button hookup confusion
hey there
It easy to insert the connector of Reset, Power, And LED
Becuse everything is used to be properly written ur motherboard,
Checkout for the lower left corner of ur motherboard.(Behind the FDD Connector's right corner)
Hookup the connection by reading on down of the every PINs on your board.
Aug 03, 2008 | MSI 651M-L Motherboard
K8T Neo ,m/board
Thanks to those who responded, . I eventually found the correct place on the MSI Global web site and downloaded the correct manual for the K8T Neo motherboard. Simple when you know how, erm ... and where. Thanks again,
Apr 28, 2008 | Intel Motherboard
Can't bring up Setup Wizard
yeah the same problem. not able to launch the wizard from the URL.
Actually i was trying to change the password for the wireless secure access and i tried typing different combinations and got in problem, then thought of doing a reset and start again the whole configuration, so i did used the reset hole and followed the instructions as listed in the document (ie like doing the configuration for first time). after restarting computer and access the URL, nothing happens, i'm not able to get the setup wizard. I also noticed that the LEDs are displaying properly as mentioned in the manual... now.. how to get it setup wizard....
plz help
Apr 15, 2008 | D-Link DI 514 Wireless Router (DI-514)
ASUS P5P800S Motherboard Logo
24 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
