Question about Nikon N55 35mm SLR Camera
Problem when my N55 is in autofocus mode the shutter wont release. It will focus, but wont take the pitcure. It will take a pitcure in manual mode.
THANK YOU FOLKS FOR THIS WONDERFUL ADVICE ... I HAD JUST ABOUT GIVEN UP ON MY N55 ! WILL BE SENDING THIS BABY TO NIKON FOR A FIX . :)
Posted on Dec 21, 2007
Here is an update to Solution #1: Nikon's service advisory for the N55 states: While only a limited number of N55 cameras are affected by this advisory, if your N55's autofocus system is not working, Nikon Inc. will service it free of charge. Use this Nikon link http://www.nikondigital.com/main.html On the right hand side select Additional Service Advisories. A link to the N55 Advisory should be listed.
Posted on Sep 27, 2007
Excellent. Exactly what I was looking for.
Posted on Apr 21, 2007
  • 513 Answers
Http://www.nikondigital.com/main.html look at the service advisory link on the bottom right. It pretty much describes your problem, same model. you are eligible to a free repair. Good luck
Posted on Jun 12, 2006
When camera is on Autofocus, and Auto exposure mode, when I press lightly press shutter release it will focus, but then when I press it all the way it won't actually take a picture. Even if I release and...
Try resetting the camera by pushing both rewind buttons (two buttons with red rewind symbol), and when the motor stops running open and close the back door then try again. If not it could be as simple as a bad release switch (the switches on the N55 and N75 were garbage) or a electronic problem. Also check to make sure you did not pop the shutter blades out of position when loading film. Remove the lens and gently lift up the mirror with a fingernail and make sure the blades are flat.
Oct 02, 2013 | Nikon N75 35mm SLR Camera
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
I understand the autofocus Nikon N55 was subject to a recall and it might have been for a shutter problem that I am having. After autofocusing, the camera will not permit me to snap the photo. I thought it...
You can contact Nikon through their website, nikonusa.com (or the appropriate website for your country), or they also list 800-numbers on the website for various countries. You can also contact a NASR (Nikon Authorized Service Representative) in your area if there is one. Keep in mind that often recalls and TSB's have a time limitation on them, and the extension for this model may have expired.
Does the focus lock indicator come on, indicating proper focus when you're using autofocus? Does it happen all the time, or only under certain conditions? Have you attempted using a different lense?
Aug 11, 2011 | Nikon N55 35mm SLR Camera
My N55 won't let me depress the shutter (to take the shot) when it's on automatic setting. I depress once (half-way) for autofocusing--which seems to work fine. No error message. But then, the N55...
Could be your lens is not communication with the body. If the lens is not telling the camera that the AF has locked on an object then it won't allow the camera to fire. Make sure that the camera is indeed locking the AF on the object. If there isn't enough contrast (for example a plain wall) then it wont be able to lock onto it. This would usually explain why it works on manual but not on auto (I assume you mean the focus setting and not the camera's modes). If you're still having issues I recommend you contact a nearby Nikon authorized service center for assistance and possible repairs. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Nikon N55 35mm SLR Camera
I have a brand new nikon coolpix s3000. it's on full-time auto focus. Any ideas?
You can change this in the menu while in shooting mode. This is from page 48 of the manual:
Choose how the camera focuses.
A (auto) M d (Shooting menu) M I Autofocus mode
A Single AF (default setting)
The camera focuses when the shutter-release button is pressed halfway.
B Full-time AF
The camera focuses continuously until the shutter-release button is pressed down
halfway. Use with moving subjects. The sound of lens drive movement will be heard
while the camera focuses.
Sep 28, 2010 | Nikon Coolpix S3000 Digital Camera
Camera will not focus in auto focus mode and when it is focused manually it will not recognize that it is in focus. The instruction manual doesn't cover this case and I was wondering what was wrong with...
You need to have a compatible lens to be able to autofocus. Some older Nikkor lenses and even more so 'generic' lenses (ie. Tamron, Sigma, Opteka etc.) do not autofocus or can be used with Nikon bodies.
Check that the lens is compatible with your camera.
Jun 19, 2010 | Nikon N55 35mm SLR Camera
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Jan 02, 2010 | Nikon D3000 Digital Camera
Shutter speed
When you set the camera to "Full Manual" mode, you should be able to dial in your shutter speeds, for most film cameras, including the N55 30 Seconds is the slowest shutter speed. If your camera features a "Bulb" mode, then the shutter stays open as long as you are holding down the shutter release button.
Apr 12, 2009 | Nikon N55 35mm SLR Camera
Nikon N55 Won't take picture in Auto Focus Mode?
There was a recall on the N55 due to auto focus problems. You can do a google search or nikon.com email the support team and they will send you the paper. This is what I did, I wasn't charged since I had the correct papers. I, however, used one roll of film and my focus went out again! Mine doesn't even work on manual... If you want to try that maybe you will hae better luck than me. GOOD LUCK!
Apr 28, 2008 | Nikon N55 35mm SLR Camera
What autofocus modes does the DiMAGE A200 employ?
AF single or AF continuous can be selected. In AF single mode, focus is calculated and set when the shutter-release button is pressed partway down. This mode is mainly useful for a stationary subject. In AF continuous mode, camera continues to focus on a moving subject even when the shutter-release button is pressed partway down. It is convenient to capture the moving subject. Full Time AF that continues focusing without pressing the shutter-release button can be used in both AF modes.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
Nikon N55 35mm SLR Camera Logo
217 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
TC CAMERA REPAIR.Com...
Are you a Nikon Photography Expert? Answer questions, earn points and help others
