Problem with Bosch 24 in. SHU43 Built-in Dishwasher
Our Bosch stops either in mid or near the end of the cycle and shows
It was working fine until a couple of weeks ago; now it's suddenly stopped working properly. It's not under service guarantee, but the parts are warrantied.
Posted by avatar on Jan 26, 2012
Suggested Solution (3)
It sound like a pump issue. Open the service panel, remove the pump and try to rotate its pulley manually, it should turn freely.In case it doesn't,check if it is clear from any foreign object or it should be replaced. Good luck !
  • by Author image Dov Dror Over a year ago
Source: under counter Bosch,grinding noise
Was this solution helpful?
No
Yes
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
  • by Author image Rylee Smith Over a year ago
Source: New SHE4AM16UC, professionally installed eight
No
Yes
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
  • by Author image charlymonty Over a year ago
Source: S5N27B keeps stopping mid cycle
No
Yes
Tips for Helping Vance Andersen With Their Issue
  • Give detailed step-by-step instructions
  • A picture or video is helpful
  • Use plain language not industry jargon
  • Check spelling & punctuation
Hide Tips
Add Your Solution
See all Bosch 24 in. SHU43 Built-in Dishwasher Problems
