Question about Video Cameras
DCR-HC28 The tape door won't open.
  • chriselsonin Oct 18, 2008
    Interestingly enough, I repaired on my own after sony couldn't help. There was a tape inside, but the door wouldn't open. So as a desperate last resort, I unscrewed the 2 small screws on the door. I had no idea what would happen, or even what I would do after that, but I took out the 2 screws and Wha la!
    The door opened!! i put the scews back in, and it works great! Don't have any idea what happened or why, but perhaps the door was a little cockeyed, and this loosed it.
    Master:
  • 383 Answers
Is there a tape inside .... how did it happen Exactly ...
Posted on Oct 18, 2008
3 Suggested Answers
  • 4234 Answers
SOURCE: on the sony dcr-hc28 i
The C32:11 error is a motor movement error. This means that a motor or gear is NOT moving when it should. As a sfety feature, this will prevent a tape from getting loaded and getting damaged. This unit requires repair. This is not typically a DIY repair as opening these up is tricky and if not done properly can cause additional damage. Check for local labor rates as well as the fixed repair cost from Sony directly. The fixed rpair cost from Sony will also include any parts that are required.
Hope this helps,
Dan
Posted on Apr 10, 2011
caroldon
  • 17130 Answers
SOURCE: sony dcr-dvd408 can't open the
This can be due to failure of the loading motor mechanism . Since you are hearing the clicking sound , it is possible that the motor is working to the command from the processor but there is failure in the mechanical drive., This can be due to pulley slipping , gear failure or belt failure.
Unless the camera is opened to remove the covers and get access to the mechanism , the exact fault cannot be confirmed.
Posted on Aug 16, 2011
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
On the sony dcr-hc28 i have an c32:11 error and will not allow me to insert a tape, I have tried other tapes?
Hope this helps,
Dan
Apr 10, 2011 | Sony Handycam DCR-HC28 Mini DV Digital...
The tape produced by PRINT TO TAPE looks as though a striped mask were placed over it. The original images show through 3 squared areas on the screen. I used a new tape. Watching the screen while the tape...
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 05, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
Sony hand cam DC R 28 The tape door is not closing
Its because mechanical cable or flex is damage.it need replace cable or complete mechanical
Sep 02, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
I get a c31:23 error message on sony camcorder dcr-hc28. Any suggestions to fix this?
That code is telling you your heads dirty, no do not buy Shampoo just a tape head cleaner from local camera centre, all will be fine okay?
David
Jun 20, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
TAPE DOOR WILL NOT CLOSE
mechanism is faulty.flex cable (FP-031-12) is broken. replace complete mechanism or flex cable (FP-031-12) by any service person.
Apr 12, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
My sony after recording when play shows horizontal lines on screen I don't know how to fix it
either the tape or the recording head is dirty. use a new tape. if the lines are still there, get a head cleaner tape or use alcohol to clean the recording head.
Jan 31, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
My sony dcr-hc28 developed a problem where the tape will not reinsert and i get a message "re-attach power source". i re-attach, nothing changes. i remove battery, power source, re-attach, nothing...
apply a DC voltage of 5v to the tape motor at the bottom of the camcorder. you'll find two little semi-hemispheres on top of motor. trial and error to figure out which is positive.
Dec 17, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
When I put the tape in, the tape does not slide down as it is and the door close. The screen display shows C:32:11. I do not know what that means. Thank you!
The camcorder has detected an issue that may require a power reset.
To power reset,
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
Aug 02, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
Unfortunately, it's not exactly a trivial process. The basic steps are as follows:
1) connect the camcorder to the computer
2) transfer the video from the dv tape to a file on the computer
3) optionally, edit the video file
4) upload the file from the computer to youtube.com
1) the camcorder has 4-pin 1394 (also called firewire or i-link) jack, and the computer (if equipped) either has 6-pin 1394 jack or 4-pin 1394 jack (on some notebooks). if your computer doesn't have a 1394 jack, you need to buy a 1394 adapter (eg. pricegrabber.com)
2) transfer the video from the dv tape to a file on the computer hard drive using editing software or a software utility designed for doing just that. this software may come with the camcorder or the 1394 adapter.
3) optionally, use editing software to take an excerpt from the file, rearrange parts of the video, add titles, etc., and output a new file
4) upload the file to youtube.com. there are some guides on their website as well (eg. youtube.com)
I hope that helps.
Aug 12, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Video Cameras Logo
101 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
