Question about Microwave Ovens
Ge spacemaker (JVM1653SH01) cuts off after a few seconds.
  • 2 more comments
  • timfore Oct 20, 2008
    You have to reset the clock. It doesn't go completely dead. It would work intermittently, but now it does this every time.
  • abeba7 Dec 01, 2008
    i'll set oven cook time press start and about 2 secs. in oven blanks out and ask to reset clock and calander. this issue constantly occures
  • goldpaner44 Mar 07, 2009
  • William Miller
    William Miller May 11, 2010
    When it does, does it go dead (no display, no beeps when keys pressed) or does it reset so you have to set the clock?
  • Microwave Ovens Master
  • 9,086 Answers
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit. The parts kit is similar to this one.
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
They may send you a replacement magnetron. GE Customer Service is here.
Posted on Oct 20, 2008
GE jvm1653sh01 range lights won't turn off
Got a short at or in the switch assembly that is causing this and unit would have to be unpowered and checked to see if one or both switches are bad.
Oct 29, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
My control panel has locked and I can't unlock it.
If this is a GE Spacemaker model, you can lock or unlock the controls of the oven by pressing and holding the CLEAR/OFF button for 3 to 5 seconds. If this is not a GE Spacemaker, please post back with your correct MODEL NUMBER. I hope this information helps you.
Jun 24, 2010 | GE Profile Spacemaker Over-the-Range...
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
After a few seconds my microwave makes a crackling
check for scraps of foil, wire ties any type of metal or tin,or aluminumif not any of that, ur looking at a componet problem
May 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave powers off after few seconds of working
Hello :
This could happen because of a bad keypad . Just replace it and problem will be solved . I need you to think before replacing it . Because sometimes a new unit is better than repairing . Think it before !
good luck .
please rate !
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker shuts off after a few seconds and asks for the clock to be reset
Ge Spacemaker comes on ok but after a few seconds the noise level goes up significantly and it does not heat. It keeps running until the time runs out but it doesn't heat.
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Cuts out everytime you put food in, any mode any food, then displays sensor on panel displayed. May run for a few seconds then cuts again Rob.
It could be either the magnetron thermostat or the cavity thermostat would be faulty, depending on the microwave but in most cases it would be a thermostat.
First of all you can try cutting the power to the unit for 5 minutes, then retry it.
Call 800-626-2005 GE costumer care You will probably need to provide your serial number when you call so be sure you have that ready.
Good Luck!!
Thanks
Oct 16, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave Ovens Logo
932 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
