Question about Frigidaire Dishwashers
I have a Frigidaire dishwasher (FDB2810LDC1) and a Er code appears in the display with the sensing, rinsing agent low, sanitized, and clean lights all flashing as is the child lock light. After seeing the Er code, I opened the dishwasher and thought I heard the detergent tray open but most of the detergent was gone with a little remaining. This has happened before and we have had the electronic panel replaced twice. Could it be something else like something blocking the detergent tray from opening?
3 Suggested Answers
  • 409 Answers
SOURCE: Error flashing and won't reset.
hi there,
PF stands for power failure. the first you should do is check your house breaker and make sure that you did not trip the fuse.
Does anything run? Can you hear the motor running? If not, you have no power coming into the machine. In this case it's the main control board that needs to be replaced.
If the motor hums, it means you have power to the d/w, in that case you need to replace the touchpad.
thanks
Posted on Oct 02, 2008
  • 3 Answers
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Posted on Apr 01, 2009
I get an Er code 5 on our Dishwasher and it keep restarting in the rinse mode
Thank you for your post, friend!
I see you are having trouble with your Frigidaire dishwasher and you are receiving error code "5". However, it appears "5" is an invalid error code. May I have you model number please? Typically you can locate your serial tag on the inside wall on the left hand side. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your dishwasher. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. -Matt
Sep 18, 2014 | Frigidaire Dishwashers
My Frigidaire dishwasher - most buttons don't work and clean and sanitized lights are flashing after cycle completes.
Hello Rich - From what you have described if only some cycles are working, then there seems to be a communication problem coming from the main control panel, I would suggest contacting a professional technician to diagnose the unit.
Sep 23, 2012 | Frigidaire Dishwashers
Frigidaire Dishwasher Model GLD4355RFS0 Will not sanitize and leaves dishes wet ?
One common issue on these units is the heater wire will fall off. If this happens, the dishwasher will not heat. Also make sure the rinse agent is full. On most of the newer dishwasher rinse agent must be used to help dry the dishes.
Appliance & Refrigerator Repair
Mar 23, 2011 | Frigidaire Dishwashers
Error code of "Er s" appears on the display and inside the light remains on at RINSE Low. HELP!
Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
Let me know how this works out for you.
Benjamin
Dec 23, 2009 | Dishwashers
Dishwasher, flashing lights, frigidaire
Jan 20, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
hi there,
thanks
Oct 02, 2008 | Frigidaire 24 in. PLD3465REC Stainless...
I have this code error on my dishwasher frigidaire gallery Sensing Sanitazed......Er......Low Clean.......................*
That will be a main control board. Also if you have a touch pad replace that also. If its more than three years do not repair but replace.
Jul 24, 2008 | Frigidaire Dishwashers
PLD4555RFC: Low Rinse Agent Light Will Not Go Out
I've disconnected the sensor in the dispenser for my new Frigidaire dishwasher. The setup is too unreliable in my opinion and is a potential source of headaches. I had the same problem. I studied the design and it's too easy for the floating magnet sensor in the rinse aid reservoir to stick thereby not actuating what is called a reed switch to toggle the control card LO ckt light. Mine has the electronic control front panel.
Jan 07, 2008 | Frigidaire PLD4555RFC Dishwasher
Frigidaire PLD3465REC dishwasher error??
Hi, I am having the same problem you describe above with the model nr PLD3460RDC1. Were you able to find out what it was? Thanks so much!
Jul 02, 2006 | Frigidaire 24 in. PLD3465REC Stainless...
Dishwashers Logo
131 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
