Question about Panasonic DVD-CV52 DVD Player
Error Message H07 - what is it?
Half-way through watching a DVD (with no previous indications of a problem), the TV screen went blank, then showed the standard "blue screen" with the word "DVD" (like you see at the start of a movie when you first insert the DVD). The player however showed "Error H07", and it would no longer play the DVD. I tried a few other DVDs, no luck. I restarted the player, also no luck. What does "H07" mean, and does anyone have a fix for it? In the meantime, I will try to clean it as per the previous fix listed for "H02".
  • 4 more comments
  • Anonymous Nov 11, 2007
    when i put a DVD disc in the DVD player wouldn't play the DVD player would say Error Message HO7 is there any way to fix this?
  • djk01 Jan 07, 2008
    HO7 message on unit, and not playing any disc.
  • Mike Benneter Jan 24, 2008
    Thanks...would have been a great solution to try if I still had my unit. Brought it to a shop, after parts & labour estimate it was not economically feasible to repair, so I bought a new player for half the repair cost.
    Excellent detail on the proposed solution, if only every "fixya" was that clear. Hope this works for you other guys!
  • Anonymous Feb 13, 2008
    I have exactly the same problem, but when I review the Panasonic parts list there is no listing for a "spindle" motor. Since this model (DVD-CV52) is a 5-disk changer, perhaps the failed motor has a different name. Panasonic lists only two parts as motors for this unit. One is item RFKPLPD667PA, described as a "TRAY MOTOR/DC/<35W" costing $14.85. The other is item RFKPLPD667PB, described as a "LOADING MOTOR" costing $15.06. Since the tray opens to accommodate DVDs or CDs, does that mean the Tray Motor is good? If so, then is the Loading Motor the "spindle" motor?
  • Anonymous May 26, 2008
    when i press play it says ho7
  • RodT May 11, 2010
    I also have an H07 problem. However, there is no listing for a "spindle" motor in the the Panasonic parts list. Panasonic lists only two motors for this unit. One is item RFKPLPD667PA, described as a "TRAY MOTOR/DC/<35W" costing $14.85. The other is item RFKPLPD667PB, described as a "LOADING MOTOR" costing $15.06. Which one is the "spindle" motor?
    Novelist:
  • 102 Answers
The last time I opened up my Panasonic DVD-CV52, I looked at the little white bush on the motor spindle, it has a small spring which presses against the side of the bush. I can see no purpose for this spring/bush other than to provide some drag to the motor. Anyway, I removed the spring, so that the bush would no longer drag against the shaft, that was a few years back, and I haven't had a problem since. Of course a temporary solution is to oil the bush!
The www.ledcar.com/pdvdh07/ link mentioned above provides an excellent pictorial guide to disassemble and reassemble the player.
Posted on Aug 06, 2008
  • BlackOnyx
    BlackOnyx Jan 01, 2014
    Just a quick update, I posted this in 2008, it's now 2014, and I have had no problems with this player, since removing the spring., some years ago.!
    President:
  • 3,130 Answers
Ho7 is a very common problem with the panasonic dvd players. It means that the spindle motor didnt come up to speed and shut down, Thus the spindle motor needs to be replaced. Good Luck
Posted on Jun 10, 2006
Www.ledcar.com/pdvdh07/
this might help you guys
Posted on Jan 24, 2008
I have Samsung 46" rear projector TV the TV just went blank
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ... the show I'm watching and then it turns ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
i have SAMSUNG led tv with NO picture and there is back light and sound OK, ... Apparently the TV was on ...
Dec 15, 2015 | Samsung Televison & Video
Panasonic DVD player RV62 H07 message - disc
You can try to clean the laser by opening the unit and wiping gently with a cue tip or cotton swab, but if you are getting a H07 errorit may be somethng more serious and require a replacementof the dvd drive.I hope this helps. Good luck.
Sep 03, 2010 | Panasonic DVD-RV62EBS DVD Player
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Error code h07
HELLO
I have just recently posted a cure for this - but here we go again. Fault H07 is the fault code for the spindle/disc motor and to cure it do this!
With the lid of the player removed, locate the spindle and where the motor shaft goes into the motor itself, use a little light oil or WD40. Let it soak in a while and try it again - you should now find it works.
Why this works I just don't know - it just does! (:-)
Sep 09, 2009 | Panasonic DVD-RV32 DVD Player
Screen says ho7, will not play dvd
This is a problem with your DVD Player .Please call to service center and tell the problem.They may either replace the system or rectify the problem in the same system itself.
Aug 08, 2009 | Panasonic DVD-RV32 DVD Player
H07 error msg
This normally means the spindle motor is faulty
Jul 12, 2009 | Panasonic DVD-RV32 DVD Player
Can't watch show while recording
It doesn't do. No can do.Whatever channel you SWITCH ON TO AFTER you started recording be it timer or manual GETS recorded. Whether you switch onto inputs on your TV remote or cable remote IS the one getting recorded.
Jun 15, 2017 | Sony Televison & Video
Error message H07
The spindle motor is defective. Open the cover and see if the disc spins when it loads. If it doesn't, give it a spin in a clockwise direction immediately after loading the disc.
Apr 05, 2008 | Panasonic DVD-RV32 DVD Player
Sharp 46D62U incompatability
Most likely a defective Main Board. I suggest calling Sharp 1-800-237-4277 to locate your local Sharp Authorized Service Center.
Nov 06, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Dvd
I opened it up and sprayed silicone on the center where the disc snaps on. I also sprayed from a side angle to try to aim it towards bearings/works underneath. It worked!
Jan 24, 2007 | Panasonic DVD-RV32 DVD Player
Panasonic DVD-CV52 DVD Player Logo
4,150 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
