Question about D-Link AirPlus DI-524 Wireless Router
Di-604 & di-524
I have just moved to a bigger house which is a back-split having 5 floors
i have a problem now that the main cable for internet is in basement area
i have 4 computers & 2 laptops i need wireless to run the laptops upstairs
how do i connect the 2 routers to achieve a wireless network upstairs
i have read many things but! i am so confused & lost as to the how to
please help
thanking you in advance
  • mauriceand58 Oct 21, 2008
    i do have 3 routers
    i have
    these are all d-link routers
    i toke off the DI-524 as my main router due to the fact it was not giving me a strong enough signal
    it would only work in one area of house being a small room just about the basement,
    i put the 604 on as the main router , i tired to use the DI-524 as the wireless upstairs i changed the setting but still i have no luck
    if you can assist me in setting these routers up i would appreciate it
  • 2,460 Answers
Ethernet will travel over 2 pairs from the basement to your space that has to be less than 100 feet away. You can run it over flat cable, but not get 100 base T, but it is still going to be as fast and quicker than a wireless bridge and regeneration.
If I understand what you're trying to do, it will acutally take 3 routers or 2 and a wireless access point. The key would be to set up one router as a wireless and the other as a bridge. That gets your ethernet signal to the back of the router. Now, you need a wirelss access point or 3rd router to make it be wireless in your space.
Most modern premisies are wired with 4-pair cable. Even if they didn't make home runs from your space to the basement, there ought to be at least 2 spare pairs in the house cable. Those 2 pairs can feed ethernet to your space where you just have to plug in a router and configure it as an access point, or let it be a wireless router for that matter with or without being a DHCP server. In my wildest dreams, I can't even think of a 5 story structore being more than 150 cable feet away, well withing the 300 feet allowed for ethernet.
Let us know what you finally do.
Posted on Oct 18, 2008
What do I have to take apart to replace floor shift gear selector cable for bf falcon
Gear Shift - Floor Mounted
1. Raise the vehicle and disconnect the transmission
shift cable from the lower selector lever.
2. Disconnect the four nuts that attach the housing 6. Remove the whole floor shift housing by lifting
to the floorpan. vertically
1. To install the floor shift housing to the floorpan
reverse the above instructions in order 6, 5, 4.
2. Place the selector lever in the 'P' position.
3. Raise the vehicle.
4. Reconnect the four nuts that attach the housing to
the floorpan.
5. Install the shift cable back onto the lower selector
6. Tighten the lock nut to the required torque to 28
7. Lower the vehicle and check transmission
operation in each selector lever detent position.
3. Lower the vehicle. 8. Check that the mode light functions correctly. For
4. Remove the centre console (Refer to section further information, refer to Section 307-05.
5. Detach the back light bulb/wiring.
I6 Floor mount shift components
Jan 12, 2015 | Cars & Trucks
We recently moved and brought our LG front loader washing machine with us. It is now located on the second level of our house and it is vibrating all over the place. Any quick fixes without call a...
make sure it is level and the floor is good and solid.
you can alos remove the lid and back panel and check the shocks and the suspension springs to make sure none of those became dislodged during you move.
Di you put the shipping bolts back in when you moved the unit?
Feb 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
How to make a d-link 264 ob into a repeater I have a three story house with wireless on the ground floor and the signal is very poor at the top. I want to repeat the signal on the second floor.
Move your wireless to the second floor or add a second wireless router to your second floor. Use CAT 5 or 6 cable. Run it in a closet or cold air return. Use the special cat 5 or 6 for cold aire return use. Do not put it in a heated duct.
Dec 09, 2009 | Computers & Internet
Cant get internet on both computers using router
When did the router stop working?
Have you tried a new cable between the router and the modem?
Since the status light is off on the router, that tells me that there is no communication between the router and modem. Is it possible that the router was reset by accident? Resetting it will put all settings to default. If it has been reset then you need to sign on to the router to setup the communication again to your modem. Typically this is done via the IP address.
I can walk you through those steps if that is the case. Try supplying a different cable though between the router and modem. Power off both of them, power on the modem and then power on the router....then try to connect to the Internet.
Mar 26, 2009 | D-Link DI-624 / DWL-G520 Kit...
Trouble creating wireless access point from D-Link DI-514 router
1. Connect a pc to the router using a cable (wireless won't work)
2. Open a browser and type in:
3. Login with username: admin password: (blank)
4. Browse around the menus until you find a setting similar to "use as access point" and select it.
5. Save settings and log out.
6. Connect a cable from a port on your main router to this router's internet/wan port.
Dec 11, 2008 | D-Link DI 514 Wireless Router (DI-514)
Very Slow internet. I used to use the D-Link DI-704P router for a cable internet connection. I have moved houses and I am now using ADSL2 . I would like to know how to configure the router to suit ADSL2 ,...
I would go to the manufacturers website. I had a linkysys router that was hard as hell to use with my dsl connection. CAble worked fine. There is a great program called Cablenut that you can download for free that will adjust your registry settings which may be your problem in the first place. Make sure you restart.
Jun 11, 2008 | Computers & Internet
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
Generally for your wired machines assuming your internet connection starts at the
phone wire coming out of a jack or the
cable company's cable.
Either of those connect to a modem device
An ethernet cable from the modem device connects to either
a computer as you have not
the WAN port of the router (very seldon the LAN side)
additional computers can connect to the
LAN ports of the router (often a block of 4)
Let me know if you need additional assistance by adding a comment to this message
Dec 23, 2007 | D-Link AirPlus DI-714P+ (DI714P) 802.11b
D-link DI-624 wireless router connectivity problems (DNS suffix)
Might I suggest that you reset the router to its default configuration by pressing and holding the reset button until it reboots. This way you will be dealing with the default configuration. Then try to use it. Remember the default login ID is admin and the password is Password or admin. Lets hope this helps
Sep 04, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Help connecting Cable Internet through D-Link DI-514 Router
what may be happening is the wireless pc as it was; needs the dns and ip address flushing, also the pc you connected the router to as you must have conflicting ip addreses Click start run then type ipconfig /flushdns. You should ensure that the router is set to enable DHCP to assign ip addreses and make sure your'e network cards on all pc's are set to obtain ip address automaticaly in the TCP/IP properties. Restart the pcs and type in your web browser and get into your router setings and check in the DHCP section that all pc's have been given an ip address. If all fails you may need to reset the router
Sep 03, 2007 | D-Link DI 514 Wireless Router (DI-514)
D-Link AirPlus DI-524 Wireless Router Logo
125 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
