Question about Whirlpool MH6150XMS Microwave Oven
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
Food placed in microwave will only cook/heat around the edges. The center of the plate will be left cool or cold. Example: Anything (say bacon)you put into the microwave to cook must not be placed within about a 3 inch diameter circle in the center of the rotating plate. All other area of the food will cook but it seems that the microwaves are not being spread over the center of the food being cooked. Thank you.
  • 1 more comment
  • papaslack2 Oct 15, 2008
    whirlpool microwave will not heat
  • Anonymous Mar 17, 2014
    microwave just cut off in the middle of heating up food. No power. Is there something i can do?
  • Anonymous Mar 25, 2014
    we just got this microwave and no manual
  • Whirlpool Master
  • 9,156 Answers
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Posted on Sep 15, 2006
  • 513 Answers
The magnetron generating the microwaves emits WAVES into the chamber (oven)that bounce around and at the points (nexus) where waves 'collide' the energy is greater, creating the 'hot spots'. The turntable in a domestic oven minimizes this effect, but the food is simply rotated through the hot spots. It could be that all your hot spots are concentrated in the periphery of the turntable, and that's the part that gets the heat. The most common cold spot for a microwave is the center somehow. Another thing I noticed is that concave dishes don't help the food in the center get any heat. try using more flat dishes, and don't put anything thick in the center, since microwaves don't heat from the inside out like generally believed, but only from the outside where the waves hit, and the inside is heated through heat transference, same as in conventional heating. Still, if you feel it's exagerated, you could have it serviced. Good luck
Posted on Jun 12, 2006
4 Suggested Answers
SOURCE:
biigg53566
  • 99 Answers
SOURCE: everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Posted on Jan 03, 2009
MicrowaveSvc
  • 9156 Answers
SOURCE: microwave seems to be working
Chances are you have a shorted high voltage rectifier diode or a bad magnetron, but it may be a bad high voltage transformer.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
If you'd rather have a pro take a look, I would recommend that you contact Whirlpool customer service to find your nearest Whirlpool-authorized service center.
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
Posted on Oct 27, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 17, 2007
We bought our countertop LG microwave less than a month ago --- it seems to tend to be hotter in the middle such as when I do bacon the middle of the middle strip always burns before the remainder are...
I always suggest that food items be placed off-center in the microwave, NOT in the center of the turntable, otherwise the food is not exposed evenly enough to the microwave energy and will not heat as efficiently as it could.
(Placing it in the center is sort of like stirring paint by twirling a stick in the center instead of pulling it around in a circle in the paint can).
Such inefficient heating wastes the energy at best, and at worst it puts a strain on the magnetron.
And it can put heat stress on the center of the turntable tray, which can cause it to crack.
Dec 07, 2010 | LG Microwave Ovens
We can't get our microwave to fully pop the bag of popcorn. If we use the popcorn button it stops before the bag even starts popping. If we preset the time, the same occurs and if we run it until its...
Always place the bag of popcorn on an upside-down paper plate.
This allows more microwaves to penetrate the bag from the bottom.
Also always place food of any kind in the microwave off-center on the tray, NOT in the middle of the tray.
Not only does it cook more evenly (think of how you stir liquid) but it also prevent the same spot from being heated repeatedly on the glass turntable, which can lead to overheating and breakage.
Sep 06, 2010 | Dacor DMT2420SS Microwave Oven
Microwave turntable won't turn
You may have a tunrtable motor or spindle problem..
This info is from GE website..( link : http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
  • Make sure the turntable is centered and seated properly. On models with a stirrer motor there is a shaft protruding up through the floor of the microwave. Make sure the turntable is securely fastened to this shaft. On models that turn on a ring with wheels attached, make sure the turntable is seated securely on the ring.
  • Check the turntable to make sure it is placed right side up. If the turntable plate is upside down it will drag on the floor of the microwave.
  • Check to make sure that there is no food or debris under the "wheels" of the turntable ring. Food can prevent the wheels from moving forward.
  • Be certain you are pressing a cook function rather than a timer function.
  • If the microwave has a turntable on/off feature make sure the turntable was not inadvertently turned off. Try depressing the turntable on/off pad to re-engage the turntable.
Sep 21, 2008 | GE JVM1850 1000 Watts Microwave Oven
I have a JVM1603BJ03 space saver micro wave. The turn table cracked in two, the plastic support device to turn the glass table has desenigrated into several small pieces. It appears the micro wave is...
Do you cook a lot of popcorn?
Do you place your food items in the center of the turntable as opposed to placing them off-center?
Both can cause repeated heating of the same spot on the turntable, which can stress it and allow it to crack.
You can buy replacement parts here.
I suggest that when you cook popcorn, place a paper plate or two upside-down under the bag and always place your food items off-center on the turntable tray.
Once you have the new parts, I would suggest at least a quick heat test. That is to heat one cup of water on high and it should boil in about 2 to 2-1/2 minutes.
If you would like to perform a more standard heat test, please see my Ask Mr. Microwave page.
If your magnetron is indeed running too hot, then it is probably dying. Sometimes - like a star - they can burn hotter right before they die.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 04, 2008 | GE Microwave Ovens
I have a whirlpool microwave, it is now 11 years old & last night the glass plate that goes in the middle shattered during cooking (not sure why), where can I replace the plate please?
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I always recommend that folks put food off-center on the turntable to assure more even heating.
It's a stirring action, so imagine how inefficient it would be to stir just by twirling a spoon in the center of your coffee!
Also, when you put your food off-center, you're not putting it in the same spot every time. That will help prevent repeated heating of the the same spot on the glass, which can lead to weakness and cracking. This is most common with microwave popcorn.
Apr 07, 2008 | Microwave Ovens
Microwave oven by ultrex
The sparking is usually due to accumulated grease or food particles.
If there is any chipping, charring or rust, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Sparking is most likely to occur when cooking small items or low-moisture foods like popcorn.
I always recommend that folks put food off-center on the turntable to assure more even heating and to protect the turntable glass.
Mar 09, 2008 | Microwave Ovens
Heat's water great , won't pop corn
It may be a food placement issue or possibly a bad humidity sensor.
I always recommend that folks put food off-center on the turntable (not in the center) to assure more even heating.
Also, when you put your food off-center, you're not putting it in the same spot every time. That will help prevent repeated heating of the the same spot on the glass, which can lead to weakness and cracking. Microwave popcorn gets hot enough to do that.
We have the entire service manual at our site if your or a friend want to look that over: http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
If you need a new sensor, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
Please write back with more details if you need further help.
Dec 02, 2007 | Sharp R-820B Convection/Microwave Oven
Broken turntable
The owner's manual is online at:
http://www.emersonradio.com/owners/MWO%20manual/MW8992SB-RD.pdf
You can contact Emerson at their number in the manual for a replacement.
I always suggest that people place food (especially popcorn) off-center on the tray (not in the middle) because the heating is better, plus the extreme heat is not always applied to the same spot in the tray each time.
Food placed in the middle will not cook as evenly.
Good luck, and we appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Emerson MW8987B/W Microwave Oven
Sharpd R-420LW
The turntable generally replaces the stirrer, which actually scrambles and stirs the microwaves as they come out of the waveguide from the magnetron. But some models, notably GE's, have both.
So if you're placing the food properly and it's still burning, since it's under warranty, contact Sharp at 1-800-BE-SHARP (1-800-237-4277) to see about getting it checked.
Oct 21, 2007 | Sharp R-420DK Microwave Oven
Microwave Turntable
Microwave popcorn gets VERY hot while cooking. Even though the turntable is made of temepred glass, intense heat applied in the same spot over and over can weaken the molecular structure of the glass. After so many expansions and contractions, it will crack because fatigue will cause some molecules to expand less than others, creating stress. This is yet another reason I recommend to my customers that they place the food off-center on the tray - not in the center. The oven also heats better when the food is off-center because the food is more thoroughly exposed to the microwave energy. Until you get a new tray, the photo below can help you.
Nov 15, 2006 | Jenn-Air JMV8208AAS Microwave Oven
Whirlpool MH6150XMS Microwave Oven Logo
4,470 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
