Question about Garmin GPSMAP 178C GPS Receiver
Garmin 178C Boots up then shuts off
The 178C will boot up, find satallites and even allow me to function between screens, however when not moving between screens it will shut off after about 30 seconds. I can push the on button and it will again boot up. Prior to this the unit functioned without problems for the past 2 - 3 years. Why is it shutting off on me?
  • 1 more comment
  • andante Dec 15, 2008
    Same problem for me, my Garmin 178C also comes on normally and after having found satelites shows me the map and location, however after approx 30 seconds to one minute it just shuts down.
  • mcfred Feb 24, 2009
    My 178C is three years old and never had a problem. Now I power in on, it finds the satalites and a few seconds later shuts off. When I try again, same results.
  • magik-mike May 25, 2009
    I have the same unit and the power lead pin on mine is also short. They are made that way.
Check the pins at the connector on the back of your unit. Make sure one of them is not bent or broken off. One of the pins on mine is missing about 1/16" of the tip. My boat repair shop says it's the power lead, but Garmin wants $200 for a generic repair.
Posted on Nov 18, 2008
2 Suggested Answers
fraywing
  • 37 Answers
SOURCE: Garmin 178C Boots up then shuts off
I've had a similar situation with a Magellan, it would power off despite being plugged in.
Its usually a battery issue, perhaps its not getting enough power? You could try to unplug it and do a "hard battery reset" depending on the type of battery. Keep turning it on and let it run out, until it wont even turn on anymore, after that plug it into a charger while off and allow it to charge completely. Turn it on, see if it still shuts off.
Posted on May 26, 2009
Why does my screen blink all the time on my 178c sounder
check your power connection, if that is still good your unit may be dying
Jul 05, 2014 | Garmin GPSMAP 178C Sounder GPS Receiver
Garmin GPSMAP 178C not boot
can we download india map?if tell me how to download and install the map in my device Gm4300?
Nov 20, 2013 | Garmin GPSMAP 178C Sounder GPS Receiver
My Garmin GPSMAP 178C screen backlight failed
Backlight problem: Remove the display, remove the light tube from behind the LCD. Buy a led panel from Ebay for around $5 and install it behind the LCD under the drfusing layers. Run the wires out to a 12 VDC source and there you have it.
Jul 13, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
Garmin 178c won't find satellites
It would appear that your Garmin has no clue as to where it is on the planet. I think a trip to the owner's manual:
http://www8.garmin.com/manuals/GPSMAP178CSounder_OwnersManual.pdf
might be your best bet to help initialize your unit. The info on how to graphically initialize your Garmin can be found on page 5.
Hope this is helpful.
Good Luck!
May 04, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
Garmin nuvi 250
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Garmin nuvi 250W GPS Receiver
Garmin 178c turns off on it's own.
Hi
Sounds very much like the wiring plug connections in the back, always overlooked but so important that connections are tight and contacting.
Jul 06, 2009 | Garmin GPSMAP 178C GPS Receiver
May 26, 2009 | Garmin GPSMAP 178C GPS Receiver
Locks up on boot
when it boots, press F8 select previous boot that worked...sounds like yu're having some disk issues, or you installed some driver that doesn't belong there...If it boots now, go to my computer, select the c drive with the right mouse, choose properties, choose options/extra check drive check both boxes and answer yes to a scheduled disk check. reboot the computer to fix the disk errors... what Pin Locked...
Jul 21, 2008 | Garmin nuvi 350 GPS Receiver
Garmin GPSMAP 178C GPS Receiver Logo
676 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
