Our two handset Uniden 2.4 ghz and our Walmart special have all quit. When you pick up one of the Unidens, there is dead air, almost like someone is on the line, but no dial tone. Nothing seems to help. I checked the line outside, we are in a RV, and it is connected, but the line was picked up by the maintenance guy to cut the grass. Thanks so much for any ideas as to what is wrong.
-   dead air almost someone is on the line but no dial tone
-   Guest
Apr 19, 2008
-   I have the DXI 5686-2, a 5.8 GHz extended range cordless phone I bought from Target 6 months ago. Both phones were "fuzzy" even when I first used them. We ended up only using the main phone and it was only acceptable within a few feet of the base.
It has all of the sudden stopped working. There is "dead air" as described in another posting when I push the talk button. The red light is still on and the other phones in the house work - both cordless and land-line. Target won't replace it because it has been longer than 3 months and I don't have a receipt. Any suggestions on a fix? Will Uniden replace it? -   2Cor7_1
Feb 15, 2008
-   when receiving call sometimes have to press talk and other times i don't-   Guest
Jan 04, 2008
-   I have TRU 9280 Series , one base, two extensions. while talking on one ex phone went dead - all 3 are dead, tried all suggestions in back of manual. Am now down to using my old (2) phones (attached to the wall) but ofcourse have lost the answering maching.
PLEASE HELP marykay3328@hotmail.com-   pink cadilac
Dec 08, 2007
-   i was in the middle of a conversationa nd suddenly the line went dead, yet it sounded as though someone else in my home picked up a phone, although we only have 1 phone, the one i was on. when i would speak there was a loud echo, like an intercom. i have tried everything to fix this. we have no dial tone, and can not call out, and all incoming calls (ringtone can not be heard) go straight to our voicemail. i know the battery is charged, and everything seems connected. please help!-   Guest
I don't have a solution, but I can say that my phone does exactly the same thing and I know for a fact it isn't the line because I'm using another phone on that line right now.
I have the same problem if my cable ever goes out since I get my phone service through the cable company. Try another phone and see if that works and if not it's time to call your phone company.
Was this helpful?
Yes
No
Solution #4
posted on Feb 14, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem. I finally just unplugged everything from the phone and the batteries and let them unplugged for about 5 min. When I put everything back together it worked. Hope it works for you.
Solution #5
posted on Dec 06, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
check the batteries if they are working with the help of a mulimeter
Solution #6
posted on Jun 29, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Make sure that the jack are in properly and then make certain that the battery is properly installed in the phone. I did this and problem cleared up
Solution #7
posted on May 30, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Can't suggest a solution; but, can let you know that another phone plugged into the same line works fine. Obviously, it's NOT a line problem. Thx anyway.
Solution #8
posted on Jan 17, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My troubleshooting instructions tells me to "unplug the base unitsAC adaptor to reset the unit and then reconnect the adaptor and try again." I did and it worked, However I have had to do this several times during the past week.
I have the uniden dect 6.0. One of my handsets doesn't work. I can answer but the caller doesn't...
(More)
I have the uniden dect 6.0. One of my handsets doesn't work. I can answer but the caller doesn't hear me.
First my phones worked great, then I started getting alot of static, now none of the phones work,...
(More)
First my phones worked great, then I started getting alot of static, now none of the phones work, when you hit talk nothing happens no dial tone sounds like someone is on the line but no one is. I have the one with an answering machine and 4 hansets. My old uniden phone still works so I had to go back to that phone, so there is nothing wrong with the phone line.
We have 4 VTech phones and after a short incient where the incoming phone line was accidentally disconnected, all the phones went dead and we couldn't call out or get calls and there was no dial tone. How do we get the phones O.K. and working again? The incoming phone line was reconnected after about 10 hours of being disconnected from the wall.
