Question about ASUS P5P800S Motherboard
The power led and reset led was both on
My problem is the power led and reset led was both on, i think the problem is my motherboard theres a way to solve this problem?? help me please...
  • zedhryx Oct 18, 2008
    but its all correct position actually when i power again my computer that it happen the power led and reset will both on..
  • 189 Answers
There is a line connection on power led that has a negative and positive maybe it inter change. Or there is an inter-change connection between your power led and reset led in *********** board.
Posted on Oct 18, 2008
Can you please show how to re-connect power led, power switch reset switch, hdd led &speaker cables to asrock k7vt4a+ motherboard diagram would be appreciated
there must be writen somwhere in the board it self. can you see the panel where you are trying to fit? see the whole board and you see the settings of it. just read what is written downwards to the first pci slots. i think this the setting.
Apr 16, 2011 | Asrock K7VT4A+ Motherboard
I had a friend transfer my computer components eg. motherboard, HDD, Ram etc, from a ugly computer case to a nice looking one, she got as far as screwing in the motherboard and hooking the HDD...
Hi:
To solve your puzzle, you need to find the manual for your motherboard. If you don't have it still, almost all of them are available online at the manufacturer's support website. The manual always has the pin out diagram for the motherboard, and from there its just a matter of plugging the small connections together. Remember that connections for LED lights have polarity, meaning that they need hooked up one particular direction for the light to work, but any switch connection doesnt matter.
Hope this helps
Oct 22, 2010 | Computers & Internet
Problem with panel front conector in Dell Dimension 2200 motherbo
The following information is to assist you in performing the right connections. You should take precautionary measures such as grounding yourself and completely disconnecting the PC form any source of power.
This picture shows the connector for the front panel power button, reset button, and power and hard disk lights: an 8x2 pin connector with 1 pin missing:
The table below lists the pinouts for the connector. The orientation of this table is the same as the picture above, this shows the top part of the connector. All the pins below pin 8 appear to be non-connected.
Each pair of pins labeled Power and Reset goes to the 2 wires for the corresponding button. The hard disk and power LED wires connect to the corresponding LEDs, you need to ensure the proper polarity of the + and - wires for each LED or it will not illuminate.
The above information is for your information only.
Mar 01, 2010 | Dell (2M502) Motherboard
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
Nov 06, 2009 | Intel Motherboard
Can't Fix FRONT PANEL HEADER on my Motherboard
Here is a link to your motherboard manual:
D845PEBT2 Manual
Go to Page 33 for the Front Panel connections...with pictures. :-)
Thanks for using Fixya.
Jun 12, 2009 | Intel Desktop Board D845PEBT2 Motherboard
KM18G pro motherboard power connection, reset sw, power sw, etc.
Hi.
You can download the manual for your motherboard here.
Inside you will find information of where does each connector go. Each connector on the case has a marking on it (HDD, PWR, RST or similar) which stands for hard disk LED, power button, reset button and so on. Connect it to the right place, and problem is solved.
If you need any further assistance, feel free to ask.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 18, 2009 | Albatron nForce2 KM18G Pro (KM18G PRO 2.0)...
Yes, *********** board has a problem. It has a short circuit. between the power led and reset.
Oct 18, 2008 | ASUS P5P800S Motherboard
Help me on how to connect my samsung motherboard!
Power>Red & white
Reset>Purple & white
HDD Led>Green+
HDD Led>White-
HDD Tx>Yellow & white
Select each pin & correspond with block on FSB M/B panel
Jan 17, 2008 | Computers & Internet
Led pins
I think you will have the an instruction manual of Packard Bell imedia 5106.In the manual an outline of the motherboard will be given.Figure out power and reset pins in the diagram given.
Usually the pins are at the corners only.
There will be labels near the pins like pwr rst etc.
Try connecting in the same configuration.
Please Rate me ;-) >Karatela
Dec 07, 2007 | Intel Motherboard
ASUS P5P800S Motherboard Logo
486 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
