Question about Akai LCT2721AD 27 in. LCD Television
Closed caption My closed caption won't turn off what can I do
  • 118 Answers
Try setting your subtitle language to "OFF".
■ Selecting a subtitle language
Select your preferred subtitle language. (The disc must contain the selected language.)
You can also select another available subtitle language during playback with the
Subtitle button on the remote control during playback.
1 Press the Setup button, then press < or > button to select Preference Page.
2 Press ∧, ∨ buttons to select SUB TITLE.
3 Press the Enter button or > button and then press ∧, ∨ buttons to select
your desired language.
4 Press the Enter button.
5 Press the Setup button to resume normal playback.
Note: Supported subtitle languages are English, French, Spanish, Portuguese, German,
Italian, Russian, Chinese, Korean and Off.
Posted on Nov 18, 2008
3 Suggested Answers
SOURCE: toshiba 62hx94 cant shut off closed caption have comcast cable
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Posted on Jan 30, 2009
SOURCE: We can not get CC Closed Captioning to turn off.
had a power outage and it said to reset the clock I went some where and changed the close caption from off to on. It was a in a set up menu
Posted on Jun 11, 2009
How to turn off closed caption
For over the air usually on the lower section of the remote look for CC or subt.
If on cable the Close Caption is controlled by the cable box not the TV. Usually there is a CC near the cable select button on the cable box remote. If not found then go into the cable box settings and look for
  1. Press the SETTINGS button
  2. Use the arrow buttons to scroll to the LANGUAGE section.
  3. Scroll to Closed Captioning and press the right arrow.
  4. Press the right arrow again and highlight the Off option
For some setups it is more complex. This link may help you with.
My Closed Captioning Won Turn Off
Jan 05, 2016 | Samsung Televison & Video
CLosed Captions won't go off. Setting says they are off.
Go back and just "look" to see if the captions are still turned off.
if it is still on CC1 or CC2, the captions are still on.
If they are, you must turn captions off and then follow on screen prompts to make sure they are indeed off.
(Did someone turn on the captions on your cable box or other receiver?)
(If they did, this may be the reason that you can/t turn them off on the TV !)
Apr 02, 2013 | Televison & Video
CLOSE CAPTIONING WON'T TURN OFF
Go back into the menu of the TV and go through the choices. One of them is to turn on/off closed captions!
Jan 02, 2013 | RCA Televison & Video
Philips 24PT6341 closed captioning won't turn off and there is no option in menu
There must be a button marked "CC" on your TVs remote control. Press it once. It will make the closed caption windwow off.
Jun 21, 2012 | Philips 27PT6441 27" TV
How to get rid of closed captioning
If pressing the cc button on the Sharp remote does not turn off the closed captioning then the closed captioning is most likely coming from the cable box or whatever you have connected to this television. You can go into the cable box menu by pressing the menu button on the front when it is turned off. That's right turn off the cable box and then press menu on it to access the hidden menu that includes closed captioning. Scroll down to closed captioning and scroll over to disable. A number of other Directv receivers have the CC located on a "captioning" tab on the "display" page under setup and for dish network:
Setting Closed Captioning:
  1. Press and release the MENU button and then select "Preferences."
  2. Select "Closed Caption."
  3. Select "Caption On/Off."
  4. Select "CC is On."
  5. Select "Done."
Sep 20, 2011 | Sharp Televison & Video
I have a Sanyo TV DP32648 and the closed caption won't turn off. i don't have the original remote and even now have a programable logtech remote. how do i turn off the closed caption
You will need to have CAPTION button on the universal remote control to turn on/off the caption, if it does not have that function then you will need the original remote.
SANYO remote model GXBJ is needed for this TV.
You can get used one for $20 on EBAY or a lot more for new one at:
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=DP32648&brand_pn=SANYO_DP32648&mode=large&v=1&uuid=A13140757813801
Aug 23, 2011 | Televison & Video
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
Closed caption
Are you talking computer or TV?
Closed caption on a TV is when the volume is muted and it prints the speech in a box on the screen. You have to turn it on in the menu.
Nov 27, 2008 | Computers & Internet
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Akai LCT2721AD 27 in. LCD Television Logo
611 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
