Fuji FinePix S304 Digital Camera
Problem for Fuji FinePix S304 Digital Camera
Fuji S304 Power Switch
By Chas on Jun 09, 2006
The power swirch no longer clicks positively to the 'OFF' position or the picture review position.I could hear something loose when I shook the camera.
Then it was dropped and the lens ring broke off and I found two tiny screws in the case.
Is this fixable?
Should I attempt a repair myself?
Any ideas?
Best Solution
posted on Jan 28, 2008
Very Helpful)
Keith Lello
Rank: Apprentice
Rating: 100%, 1 votes
Loose Screws in Fujifilm S304
Because I am a qualified electronics technician, when the opportunity to purchase a second hand S304 which had "issues" presented itself I took the chance. One of the issues was the switch assembly. When I opened the camera, I too found a screw rattling around inside the case.
All the other internal screws were loose and I concluded that the assembly line clutch on the robot which tightens the screws was faulty on the day of manufacture and none of the internal screws were sufficiently tightened. I tightened all oif the internal screws, some of which were partly unscrewed, and I had a very nice camera.
Lately the beast has been prematurely switching off in camera mode which is becoming a problem but I believe this is a different issue.
As it is likely all the serial numbers of the S304's with this fault will be in a given range, so that you may identify if your camera was manufactured around the same time as mine (and therefore likely to have the same fault) the serial number of mine is 24L47749 and it was manufactured in Japan.
Keith Lello
Was this helpful?
Yes
No
Solution #2
posted on Oct 18, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
May I know the detail steps how to fix the switch assembly issue ?
Solution #3
posted on Jun 12, 2006
Not Rated)
silly girl
Rank: Wiz
Rating: 81%, 3615 votes
not if you have never done this before.
It sounds like something that a local repair shop could fix. Just note that even if it's a minor fix, and the shop suggests to send it to fuji, you'll be looking at a very high rate. 100$ and up. look for someone that says s/he can do it in-shop.
good luck
Was this helpful?
Yes
No
Popular Solutions for Fuji FinePix S304 Digital
Questions and Unsolved Problems for Fuji FinePix S304 Digital
Do you recommend Fuji FinePix S304 Digital Camera?
Answer
Answer
This morning I showed my family the pictures on my Fuji camera which I took in Bangkok and... (More)
Answer
Hi, No damage, no water, no something unusual is happened to the camera (the new one: only 2 month).... (More)
Answer
my camera FUJIFILM FinePix A400 has a focus error. The zoom is locked. Does anyone explain how I fix... (More)
Answer
i brought this finepix s1000 last year ago and now the display show "zoom error" when i... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital... Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
