Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Saeco grind settings - Starbucks Saeco Italia Digital Barista Coffee Machine
  • 29 Answers
I have a saeco royal my machine is grinding beans but will not stop
Your question is not right.
Grinder stops on its own in 16 to 18 seconds (times out).
It may not be grinding beans an spinning free because the beans are not feeding.
You may have used oily beans or set the grind fineness at very fine powder like. This powder like fineness also clogs the grinder..
You need to clean the grinding chamber and the ground coffee outlet.
Dec 19, 2016 | Saeco Coffee Makers & Espresso Machines
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know
Apr 09, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
Change the grind in Saeco Vienna Deluxe coffee maker
Hello kgspco.
You will need to work the 'dial knob' untill it free's it-self.
The higher the number the Coarse(r) the grind.
If you want rich - dark - strong coffee, set number between 4 - 8.
(if you can free it up - keep trying
Jul 06, 2009 | Saeco Vienna De Luxe Espresso Machine
The Saeco Incanto machine grinds away but no water or coffee
Are there any grounds in discharge tray and if yes are they wet or dry?
If they are dry then the machine has a water circuit problem. If they are wet then the brew unit is blocked or the grind settings need to be adjusted coarser.
Jun 29, 2009 | Saeco INCANTO DELUXE Espresso Machine
Saeco Magic de luxe not grinding beans
Try setting the grind to the coarsest setting, if you still have the same problem, check the wire connections to the board, it might have been reversed.
May 05, 2009 | Saeco Magic De Luxe Espresso Machine
Long time for drip coffee.
Grinder is set to too fine. Lower grinder settings. Keeping the machine at current settings with drip extraction will result in brew group clogging, gear stripping, and/or dulling of grinder burrs.
Jan 30, 2009 | Saeco Vienna SuperAutomatica Coffee...
Making Espresso shots... how does the macine do this? Not in man look to the left for Saeco Home Models, select that, then go the model you have and download the manual.
On a magic comfort it has two settings for adjusting the espresso shot besides the amount of the shot. .
On a magic comfort plus,
you can adjust the grind size, the amount used for the shot, preinfusion (a short shot of hot water on the grinds before the unit passes all the water through the puck (coffee grinds), temperature and amount of water for shot
Also, when setting the strength on this machine, don't use a full grind amount as it can jam the machine. use a setting of 6 or 7 max for strong shots, not the 8 or 9 setting!!!
Dec 03, 2008 | Saeco Magic Comfort Plus Espresso Machine
Saeco Easy dispenses first, then grinds
I think you have pre-brewing on your machine, if you have a Sirius then you have these settings in the menu under coffee settings.
I don´t think this is on Saeco Easy, only if you will make two cup of coffee, then the machine will pre-grind the beans for the second cup.
Aug 23, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
