Question about Proview PL926WBi 19" LCD Monitor
Popping sound, black screen
I have a 19" DCL LCD monitor.
I shut down my computer and the monitor would not shut down. The power light kept alternating on and off. I tried shutting it off with the on/off button, but that would not work, I finally just unplugged it.
Today I powered up my computer, and the monitor just sits there with a black screen, making this little faint popping sound. I tried to power it up with the on/off switch but the power light does not come on.
Has it bitten the dust?
    Top Expert:
  • Proview Master
  • 43,997 Answers
Has it bitten the dust? Probably.
Posted on May 18, 2017
SOURCE: LCD display Proview
You need to contact Proview. It is a problem with the monitor. I had the same problem and I was lucky. The warranity was going to run out in 15 days. They sent me a return number "I had to pay shipping and insurance" and they sent me a replacement. The replacement had a problem with the screen. It looked like it had been shot by a bb gun. Proview is refusing to replace. Hope you have better luck. Here is their contact info.
By Phone:
Service Hotline: (800) 776-8439
Office Hours: 8AM to 6PM Pacific Time
Posted on Jun 01, 2008
The power inverter is the problem and the only way to fix it is to replace the board. It was a poor design and my Proview 19" experienced the same screen issues as those previously stated. You'll pay $25 for shipping and up to $65 in repair costs. The kicker with Proview is the lousy 1 year warranty. I threw my Proview away and purchased a Hanspree 19" with a 3 year warranty.
There is a 3rd party repair facility in TX that specializes in this type of repair for a flat rate of $75 but that doesn't include your cost to ship and insure it. Another possibilty is to buy the invereter yourself and break open the back and replace it. If you can find the correct part it should run you about $35.
I rank Proview monitors in the same category as the Koss Home Theatre, which is JUNK!
Posted on Sep 14, 2008
SOURCE: Monitor screen remain black,power supply ok
Change monitor
Posted on Feb 04, 2009
SOURCE: ma-982kc (900P)
"IF YOU HAVE THE ON FOR A FEW SECONDS AND THEN OFF PROBLEM, DONT REPLACE ANYTHING UNTILL YOU HAVE TRIED THIS" hey guys i have the 2second problem aswell but!, i was just about to throw mines away when i can stumbled across away how to get it working proper again and again and again!. ive seen lots of help pages like this where everyone is talkin about replacing parts, but if u screen flicks on and then off it should work with my quick fix. heres how and i hope it works for you. Boot up ur pc as u would usually and wait awhile untill you think everything has loaded up or has reached the logon stage. Then if you look carefully at ur screen and press the menu button you should be able to see it thery faintly (i shine a lamp at it to see better). Then i cycle through OSD (on screen disply) menu using the up or down buttons on my monitor untill i see the "AUTO" option. at this stage i press MENU button "2 times" Then i cycle through the OSD untill i see the "RESET" option and again i press the MENU button to confirm the reset. Then simply press the power button to switch it off and then back on....HEY PRESTO! it working again. I have told 11 people this fix and they all reported back that it works for them 2. this method should work every time aslong as you stiil can see the green LED on ur monitor.
Posted on Jun 13, 2009
  • 3 Answers
SOURCE: proview pl716s monitor will not come on
i just had this problem with my screen (proview pl716s) if you open the case and take out the power board, there are 6 470 uf capasitors bundled together and 1 220uf capasitor replace all 7 and that should fix your problem , that is what i did and it worked like a charm , oh and btw make sure before you swap your monitor from an older standard monitor to the lcd make sure the resolution is high enough becuase if it is not then the monitor will not be able to be displayd , hope that helps
Posted on Jul 22, 2009
The monitor comes on and then goes black.
Sounds like your LCD panel lamps are shutting down, this could be either due bad tubes, or more likely lamp driver power supply is faulty.
Jan 12, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Monitor just went blank, no power light.
Was the PC running, and then shut down? Or, did it never start in the first place?
It sounds like it could be one of many things. Sometimes if the processor fan has failed, the computer will start up, and then shut down. Also, bad memory can cause the PC to shut down.
Jul 05, 2009 | Samsung SyncMaster 940B 19" LCD Monitor
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Black Screen
Edwards,
What you mean by replaced the fuse? Are you replaced the capacitors on the AC Adapter. If so, Then it's not the only problems. The main problems is the backlight inverter needed to be replaced. Go check out my website @ www.3rd-rocks.com
and click on LCD Parts. If you have any questions just email to to me @ cjt@3rd-rocks.com Have a nice...Happy July 4th!
CJ
Jul 04, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
SCEPTRE DCLCD 20" MONITOR
plug it out and take for repair from technician or if you are a technician . there is problem in the main board where power comes in.
Apr 18, 2008 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Settings for dcl lcd monitor
Your laptop resolution is greater than the external monitor can handle. From your laptop, try changing the screen resolution to 800x600, if it works, up the ante to 1024x768. You can bring it up again until you find a comfortable screen resolution. You will eventually stop to a point when your external monitor displays about 80% of the laptop screen. That is, back to your original problem. But you get the idea. Cheers!
Mar 27, 2008 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Pin stripe screen
your video section video amp. ic dry solder.
Feb 29, 2008 | Microsoft DCL 9A+ 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
75 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
