Question about Saws
Changed delta saw blade
I took y Delta 10" miter saw apart to change the blade and cannot get the blade guard back on. Do you have diagram?
  • jakellp32000 Jan 15, 2009
    I need to put on the blade and I can not get the screw from turning the hold wheel
  • 239 Answers
It turns the other way, to the right!
Posted on Feb 07, 2009
Need a lower guard for delta model 36-220 10 inch miter saw pn 1343989
That part is no longer available from Delta or any parts supplier
Sep 22, 2012 | Saws
How do you "unlock" the Delta miter saw?
To unlock a miter saw, push down on the saw to unlock the head and loosen the knob on the table to make adjustments. Start using a miter saw with help from a custom furniture maker in this free video on woodworking tools. Read more: How to Unlock a Miter Saw How to Unlock Miter Saw Best Miter Saw Reviews Real Man Miter Saw
Oct 22, 2011 | Delta SM100M 13 Amp 10" Compound Miter Saw
How do i change the blade on my delta 10" mitre saw
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Nov 23, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
Change blade miter saw
Un-plug the saw. Remove the screws holding the side saw guard in place. Look at the center of the saw blade for the nut holding it in place. Take a socket wrench that fits the nut and loosen it. You'll need to take a scrap piece of wood 2x4, and jamb the teeth of the blade into it while loosening the nut. The nut will come off first and then a washer/spacer.
Reverse the order for installing the new blade. Make sure you use the proper size diameter blade (10 inch) and mounting hole in the replacement blade. Also, use the provided washer/spacers that were on the original blade and secure the nut. Spin by hand to see if everything clears. Mount the protective guard back on. Plug in the saw and test cut .
Good luck. If you are still unsure - ask a handy neighbor to help. It takes about 5 minutes to complete this task.
Oct 05, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot.
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
How do I change the blade on a Delta 10'' mitre saw Model 34-079? Thanks!
Please see the instructions given for another similar problem post by clicking here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 21, 2009 | Delta 79 803 3' Miter Table System
I have a 10"DELTA Miter Saw and need to change blade. Please describe how to remove and replace blade. Thanks
Without a model number I cant look for this saw, but if it is like the other mitre saws that I work on, the lower guard should have a bolt holding it in place, loosen the bolt so you can move the guard and the blade bolt is usually LH thread, on the backside of the gearcase by the blade there should be a spindle lock, rotate blade until it locks and then remove bolt. If your saw is different please give me the model number and I will pull up a schematic and look at it.
Jan 16, 2009 | Saws
Saws Logo
439 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
