Question about Canon PC-1060 Black and White Copier
PC1060 COPIER NOT MAKING COPIES - BLANK PAPER COMES OT
  • 318 Answers
Remove the drum unit,there are two clips that keep the drum and developer unit together make sure they are hooked in place.
Posted on Oct 31, 2008
I have a Minolta CSPRO EP1083, it stopped making copies, the paper comes out blank. I put a new toner bottle in and the paper still comes out blank.
Problem on lower charger.Some times wire was broken .It has 2 wire one saparation wire and other high voltage wire may any one broken.Assemble new wire may be it fix problem.Other lower charger was damaged ,need new one .If you try clean all socket and dry.I hope your copier good working.
Aug 02, 2011 | Minolta EP1083 CS/PRO Copier
I JUST BOUGHT A SHARP AR-5127 COPIER..WHEN IT COPIES, IT BRINGS OUT BLANK PAPER. I REMOVED THE CATRIDGE AND IF I TURN IT UPSIDE DOWN,SOME BLACK DUST COMES OUT...PLEASE SOMEONE HELP ME
Hi iheanyippaul,
I see you concern, I believe you will need to check your toner if it is placed properly inside the machine seems that it is not locked/latched in its place to be able to print properly reason why you get a blank paper and black dust when printing.
Remove the Toner and re insert it again making sure the toner is set properly inside and also make sure the correct toner cartridge is installed, an incorrect or incompatible toner can cause issue of not getting to print anything on the paper or possibly not fit inside the machine correctly.
I hope this helps.
Have a nice day,
mvincentc
Jul 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
Dirty copies on Canon PC1060
First replace drum cartridge
Nov 04, 2009 | Canon PC1061 Copier
My copier is making copies that have a big blank area
Hi, first if you mean length of the page, remove the ink cartridge and see if a piece of paper is stuck on the roller where the power comes onto the paper, in line with that white line on the copy.
Aug 11, 2009 | Ricoh Office Equipment & Supplies
Second blank page comes out after copies
check paper size setting and paper pickup
Jun 27, 2009 | Canon PC1061 Copier
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Make sure you remove the seal tape on the new cartridge thats why it making noise then install properly.
How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Jan 05, 2009 | Canon PC1061 Copier
LANIER COPIER 7313
I guess by your fault description that there is a blank gap before the printing starts? The only way to cure this problem is to replace the registration clutch as it is turning on too late and not releasing the paper quick enough. Also check that the paper tray dial is displaying the correct paper size and position.
Thanks Jason
Aug 15, 2008 | Office Equipment & Supplies
Canon PC1060
The fuser comes out the left side, not from the top of the copier.
Jun 20, 2008 | Canon PC1061 Copier
Canon PC-1060 Black and White Copier Logo
74 people viewed this question
old marine
old marine
Corne Viljoen
