Question about Frigidaire GLTF2940ES Front Load Washer
Water under front loading machine
When I wash a load of clothes, I have water coming out from under my washer. It seems to be more and more with each load. I can't tell where it's coming from and don't even know where to start looking. Any ideas?
  • Kim Shrum Oct 18, 2008
    I think I might have fixed it! I pulled out the "drawer" where you put the detergent/fabric softener and cleaned it. I do this about every other month. This time, however, I started wiping out where the drawer pushes into and boy did I ever find a huge mess! There was a HUGE glob of muck. I'm guessing it's just deposits of detergent and fabric softener that have built up over the year and a half that I've had this washer.
    After that was all cleaned out really good, I placed folded up paper towels all the way around the washer in hopes of seeing exactly where water might be coming from. I checked it each time it changed cycles and the towels are completely dry. It's going through it's final spin right now with about 3 minutes left and there is no water on the floor!!!
    I wish they'd tell you things like this when you buy the washer...or at least put it in the manual! Very frustrating!
  • 958 Answers
You really have to open up anything that you can see the inside to watch where the water could be dripping. check if you can open the back panel or the top cover, just to peek inside.
could be on a loose hose or a broken hose or a water pump seal leaking.
tnx 4 using fixya,
Posted on Oct 18, 2008
  • francis rivero Oct 19, 2008
    I'm glad you were able ti fix your washer.
    yes you are right. they should have thoughts of problems happening after 5 years and could have indicated in the manual.
    well, you know these people, they dont test the unit that long.
    tnx again for using fixya,
    p.s. please don't forget to rate the solution.
No seems to be getting in, wash comes out damp n dirty
Is this a new washer or has there been a change in it's functionality?
Front loading washers do use very little water. One must be careful not overload them and also to be sure to use the detergent that is made for them. Can you see the clothes and water sloshing around? Try a small load with HE detergent and make sure to use the very small amount recommended and let me know if you still have a problem.
May 07, 2014 | Frigidaire ATF6000ES Front Load Washer
Clothes come out dirty in front loaded washer
Check the level sensor at the rear of the drum.
May 16, 2017 | Whirlpool Washing Machines
I just put in my first load of clothing in my new machine. It does not seem like there is enough water flowing into the machine. I cannot see a water line while the clothes are being washed. It seems to me...
If this is a HE unit it's probably fine. Front load units determine how much water to add based on how big of a load you put in. As long as water is flowing (waterfalling) over the clothes as the machine tumbles then it is fine. Try a larger load and see if the water level increases.
Apr 06, 2011 | Samsung Washing Machines
We just bought a front loading machine and it seems to have hardly any water while washing. How much water should there be? Right now it looks like only the clothes are wet but no other water sitting in...
Front load washing machins are very water conservative. In fact a lot of moldern F/L washers use so little water that it doesn't even come up to the bottom of the door.
If the machine completes it's cycle, it obviously 'thinks' it's getting enough water to continue..
IMPORTANT...Do not overuse detergent!! This can seriously shorten the life of a F/L...! You're treating the amount of water...NOT the amount of clothes...Happy Washing
Good luck....Nomess
Aug 04, 2010 | Samsung WF203ANW Front Load Washer
Thumping hitting front stops on wash cycle.
if it was not NEW and under warranty, you bet i would ask for your paid service in heartbeat.
the repairman is arriving finally tonight.i will update what he finds.
Apr 05, 2009 | GE Washing Machines
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Washer water level low, clothes come out dry !!
This is the water saver feature and the only solution may be to put it on the maximum wash cycle to get clothes really clean.
These washers normally get the clothes almost dry.
Mar 04, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
54 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
