Question about Linksys WAG200G Router
DSL link is not stable and unable to establish broad band connection.
I have purchased Linksys WAG2 00G modem on 23.05.2008 and its S.No.is SN600H572748 but could not use till dateas DSL link on Linksys WAG200G router is not stable whereas on the same telephone line ZTE modem works quite satisfactorily without any disconnection. The DSL link blinks for few seconds, then becomes stable for few seconds and ultimately it goes. But Broad Band connection does not work. BSNL department is not ready to take any action for line problem because their modem ZTE works on the same line properly. Please help me & guide for this problem
I had similar issues with my Linksys WAG200G WiFi ADSL modem/router. I tried with hard reset and reconfiguration and even upgraded the firmware. However things did not work.
I stay at Vasai, Dist: Thane, Maharashtra, IN.
I one day observed that when there is no electricity (as there are schedule power cuts in my region) and while my Linksys router is on the (sine wave) inverter power. The link is stable and the ADSL fluctuation (rather frequent fluctuation/disconnection) starts when the mains power comes back. I observed this situation for couple of days and then tried and switched off the mains once when my router was giving issue and Bingo.. the ADSL connected instantly and was stable again. This could possibly be due to the voltage fluctuations with the mains MSEB power supply.
Conclusion: The power fluctuation tolerance with Linksys is not that good as compared to some Indian made ADSL modems. I am planning to install a small UPS for my Linksys router as a permanent solution.
Regards. Jordan Dias
Posted on Jun 10, 2010
I (and several others) have had a similiar problem, especially with use of torrents... in the end the best suggestions are as follows, but do them one at a time and see how you go each step...
1) Upgrade firmware from the site and then soft reboot the device.
2) Reset modem - as mentioned by kakee.
3) In basic setup change your MTU to manual and set to 1300.
If all this doesn't work contact Linksys customer support as you may have a faulty device.
Posted on Oct 21, 2008
    Genius:
  • 1,269 Answers
I suggest you to do a hard reset on your router. Press the reset button at the back of the router for 20 seconds then unplug the power for 1 minute. Then reconfigure your PPPoE settings. On the Setup page of the router, make sure to choose the "Keep Alive" option.
How do i find my access point name my broad band t-mobile & im working with windows 7 if any one can help that would to great thanks
Your "access point" means the thing that your computer connects to in order to get on the internet. An "access point" can be the dsl modem, a router or switch inbetween the computer and the internet connection or the point of entry to the internet - depending on what you are using to connect and get on line.
You mentioned you have a broad band connection with t mobile. Is this the T mobile home service link that gives you regular phone service and internet? If so - what is the name of the box your connecting your phone and pc to?
What is the name of the equipment that t mobile gave you to use that broad band link?
Are you using a desktop or a laptop? Wireless connection? or a wired connection with a ethernet cable (looks like a phone cable but a little bigger on the plug end)?
To answer my questions go back to your original problem posted on fixya and use the comment or reply link in blue.
Mar 26, 2011 | Sony Computers & Internet
My compaq presario V2000 will only connect to dialup
To connect to your DSL internet you will need an ethernet port or wireless card on your laptop. Your laptop should have an ethernet port, it will look like a phone jack but a little bigger. In the off chance that you don't have an ethernet port on your laptop you can also purchase an ethernet to usb adpater. You may have a wireless card installed on your laptop, but if not you can purchase a usb wireless adapter. To use your internet wirelessly in your home you'll also need a wireless router. All of these things can be purchased at your local electronics store (walmart, best buy, kmart, frys) and usually are fairly easy to setup with the included instructions.
Feb 15, 2010 | HP Compaq Presario V2000 Notebook
Broad band connection
we have on type4 modem (zxdsl 531b) how can i connect two pc with this modem
Aug 26, 2009 | Computers & Internet
Linksys router model WRT54GX2 SRX200 drops wireless connection on the laptop and the ethernet connection on the desktop. Connection drops for seconds then reconnects in seconds. By-passing the router and...
read on the router if its broad band , if is not , you will not be able to use it , so my advice to you is get aother linksys router with broad band on it .wish you all the best
Aug 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Cannot establish broadband connection from cd
Try downloading drivers for the device. Google is youre friend :]
May 27, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Linksys wirless G 2.4 broad band router download driver
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Feb 10, 2009 | Linksys Wireless-G WRT54G Router
Xbox360
Hello taz1028,
In order for you to be able to log into Xbox Live, you will need to have DSL or Broad Band internet connect in your home. Once you have that, you will be able to connect the Xbox 360 directly to the Modem that the internet provider gives you. If you wish to able to connect both the Xbox and your notebook to the modem you will then need a router or a wireless router. So, if you do not have DSL or Broad Band Internet service in your home, you will not be able to log into Xbox Live.
Sincerely,
Agent Xiong
May 31, 2008 | Microsoft Xbox 360 Elite Console
Internet connection
I think your modem needs to be configure by your ISP.
I change my modem here in my house with other brand and did'nt work, so i put the original modem i used and it works again..
Nov 13, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Linksys WAG200G Router  Logo
1,314 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
