Question about Intel D946GZIS Motherboard
D946GZIS Motherboard taking direct power supply
Dear Friends,
I am using D946GZIS Motherboard. from the past one year or so this board is taking direct power supply. and sometimes rebooting frequently. pls let me know the solution.
regards,
kumar raja
9701552565.
rajamail68@gmail.com
Instalesoin matherboard driver
Posted on Feb 20, 2009
  • ikram1984 Feb 20, 2009
    D946GZIS Motherboard driver instaletion
Solve the problem dual core 2.8 processor not supported intel 946gzis motherboard.My processor is heating.I have apply to the processor with cool paste.before apply the cool paste my pc is working.Af
If your pc worked fine before then why it shouldn't support. Consider the following :
# Check whether you have insert the processor to the motherboard firmly or correctly (your pc won't boot if you fail this condition)
# Check whether you have insert all the power supply cables in place if you remove earlier
# Check for any unusual events after or before you switch on
Oct 19, 2012 | Intel D946GZIS Motherboard
Intel D946GZIS machine will not start after being reassembled. The green light on the Motherboard is on but after hitting the power button nothing happens
It is more than likely the power supply that is faulty. Newer PSU's have a 5volt supply missing, this means that some older boards will not run with the new PSU's. Try and find an exact match for your older supply but with a better power rating, if that is what is required.
Jun 24, 2012 | Intel D946GZIS Motherboard
Where can i have drivers cd for intel d946gzis motherboard
Try this link. I hope it helps.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+946+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D946GZIS
Oct 22, 2010 | Intel D946GZIS Motherboard
HOW TO INSTALL MOTHER BOARD
These general instructions are intended to supplement or simplify some of the information in your motherboard manual Step 1 Make sure to read the manual that came with the motherboard - instructions differ for each one.
  • Step 2 Ground yourself with any professional grounding equipment you have. Otherwise, ground yourself by touching the computer power supply.
  • Step 3 Place motherboard on its anti-static bag.
  • Step 4 Configure motherboard: Set jumpers or DIP switches for CPU, voltage(s), and bus speed, if necessary. If your motherboard is configured by software, you will need to configure it after you complete the physical installation.
  • Step 5 Position motherboard in case. Line up holes in board with holes in case.
  • Step 6 Insert spacers, plastic stand-offs, washers and screws, as necessary. Tighten screws carefully, but securely.
  • Step 7 Make sure motherboard is not touching metal anywhere.
  • Step 8 Make sure slots and connectors fit into openings on back of case.
  • Step 9 Connect motherboard to power supply.
  • Step 10 Connect CPU fan, if you have one, to power supply.
  • Step 11 Connect reset and power switches to power supply.
  • Step 12 Connect LED indicators to power supply.
  • Step 13 Connect case speaker to motherboard.
  • Step 14 Check all connections.
  • Step 15 Test motherboard (and configure in CMOS if necessary) before installing other components of computer system.
  • TIPS AND WARNINGS
    • If possible, do installation in an uncarpeted area.
    • Be careful not to touch any chips. Handle board by its edges. Static damage (and even oil damage) may cause a failure months after the incident.
    • If you do not understand these instructions or you lack good manual dexterity, have a qualified technician install the motherboard for you
  • Mar 20, 2010 | Intel D946GZIS Motherboard
    Problems with Intel D946GZIS Motherboard
    Hi pbkajey, This Asus board will easily handle your 3.4GHz CPU & fully supports 1600/1333/1066/800 MHz FSB.
    Suggest this motherboard:
    http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4244469&SRCCODE=GOOGLEBASE&cm_mmc_o=TBBTkwCjCVyBpAgf%20mwzygtCjCVRqCjCVRq
    The only catch is this board runs, DDR3 memory. Up to 16GB of Dual Channel memory.
    Asus link for the P5Q3 MB:
    http://usa.asus.com/products.aspx?l1=3&l2=11&l3=709&l4=0&model=2563&modelmenu=2
    Review:
    http://techreport.com/articles.x/14655
    Asus comes with an impressive three year warranty. Most manufactures support 1 year only.
    Here is another Asus board that will run your CPU & DDR2 memory:
    http://usa.asus.com/products.aspx?l1=3&l2=11&l3=709&l4=0&model=2581&modelmenu=2
    Same 3 year warranty. There are two boards that support the 945 chipset below:
    http://www.asus.com/products.aspx?l1=3&l2=11&l3=707
    Keep in mind you do not have to keep the 945 chipset. The newer boards still support 945 & better.
    The choice is your's.
    Good luck pbkajey!
    More question? Post here.
    Mike
    Nov 19, 2008 | Intel D946GZIS Motherboard
    Sound problem in D946GZIS
    I am having sound problem with motherboard D946GZIS .
    I have installed WINDOWS VISTA.
    The sound use to come as if the playback speed is too slow but the video use to be at normal.
    Also, the volume of sound use to be too low
    May 21, 2008 | Intel D946GZIS Motherboard
    Intel D946GZIS Motherboard Logo
    172 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
