Question about Frigidaire 24 in. GLD2250RD Built-in Dishwasher
Lights flash but wont start
This dishwasher is less than 6 mo. old, has been operating fine but just started this problem. The door is shut properly, has power, water, all else appears as should be, but will not power up, only light flashing above "normal wash" when selected, and then light flashes beside "washing"(and beside "normal wash") when "start" is selected, but nothing else happens.
  • 3 more comments
  • arlenemx Nov 03, 2007
    Same problem.... I am adding water to see if it will kick on... So far nothing.... How much water does it need?
  • petyeaty2 May 19, 2008
    i have the same problem. the normal button and wahing button flashes, all because i opened the door when the washer had starting running and filling up with water, now it wont go any further..
    any ideas on how to start it again? other than the ones mentioned.
    thanks
    rick
  • Danigirl2008 Jun 14, 2008
    I pulled the built in dish washer out to replace gasket on top..........was working fine and now all lights are flashing. I unplugged it and then when I plugged in again everything looks the same except when I go to push start the Washing button now just flashes.
    I feel like big hammer might work.......snicker snicker....any suggestions?
  • nakulskiv Jun 20, 2008
    lights flash on dishwasher frigidaire brand but wont start
  • Mike6365 May 09, 2009
    My problem is basically the same but the Normal Wash light is the only one to flash. If you push start the cancel light will illuminate but once you let go the Normal light is the only one to flash. We had run the dishwasher the day before and it operated normally. Does anyone have an answer?
  • 3 Answers
Sounds like the pump has gone and cant circlate the water. Raise it up and if the water can siphon out, then the pump is a goner.
Posted on Jun 16, 2007
  • 641 Answers
If the dishwasher is still under warranty, best thing will be to conntact for manufacturer service !! The problem you describe could be cause off : * A Defective switch level that doesn't "shows" that there is enough water in the dishwather and therefore will prevent program's advance. * A defective heater- If water will not reach need temperature it will prevent program's advance as well. * Defective timer - Dishwasher's heart. In case your washer is over its warranty period and you would like to solve your problem by yourself, let me know and I will instruct you step by step how to to find the defective part and how to fix it. Good luck !
Posted on Jun 09, 2006
The start light is flashing on my GE dishwasher?
What's the model number? How old is this dishwasher? The new GE dishwashers (less than 3 years old) have a weakness in the door switch/latch assembly, and that would cause the light to flash - it wants you to press Start and close the door, but it's not recognizing that the door is closed.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 10, 2015 | GE Dishwashers
Does my whirlpol du1145xtpb1 dishwasherr need to be reset
SERVICE DIAGNOSTICS CYCLE
To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
Heated Dry, Normal, Heated Dry, Normal
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Read more: http://forum.appliancepartspros.com/dishwasher-repair/261055-whirlpool-quiet-partner-ii-clean-light-flashing-have-reset-still-flashing.html#ixzz2UOcsE2Yg
May 25, 2013 | Whirlpool 24 in. GU3200XTP Built-in...
Blinking lights on frigidaire dishwasher
Hello - Try resetting the dishwasher by disconnecting the power to the unit. This will clear most flashing lights. You can disconnect power by flipping the circuit house breaker off and back on for approximately two minutes. If this does not prove to be successful, contact a professional to move forward accurately. Dishwasher could possibly have a faulty control board or wiring failure.
Oct 10, 2012 | Frigidaire 24 in. PLD2850 Built-in...
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
DISHWASHER
one of the switches in the door latch are not making contact properly. before you take the door apart make sure the dishwasher is 100% level. this can affect the door lat switches
Nov 22, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
LIGHTS FLASHING ON PANEL
The lights flash when the door is not shut all the way, or the sensor that detects that the door is shut is not sensing the door is shut. Try pushing in on the door while hitting the start button.
Sep 11, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Frigidaire model FDBB2040FSO
Make sure the door is shutting all the way. Mine does the same thing if the door is not latched.
Sep 08, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Kenmore dishwasher 16182 won't start
make sure the door is closing properly. if the door is closing properly you could have a door switch problem.there may be other problems but i would check the door first.
Mar 23, 2007 | Kenmore 24 in. 16182 / 16189 Built-in...
Wont start
Feb 13, 2007 | Frigidaire 24 in. FDB1051RE Built-in...
Dishwashers Logo
494 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
