Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
GC5SHEXNS Whirlpool icemaker not producing
My icemaker is not making ice and I have reason to believe my problem is the optics sensor. Please advise how I can confirm and if necessary replace?
I had the same problem. What was happening to my was the silver tube where the water comes out was frozen. I pulled it out and put in in hot water then i put it back in. I also used a hair dryer to make sure nothing else was frozen inside. It works fine now. My frig is 18 yrs old. Now since last night I heard a loud sound like glass breaking. The noise is comming from the motor. We took the backing off to check. The freezer is starting to defrost so my quess is its on its last leg. Maybe someone out there can give me some pointers. Thanks Mrs Ruiz
Posted on Oct 26, 2008
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
How do i fix my whirlpool icemaker it seems that it gets stuck half way into icemaking and does not produce ice.the model is ed5hhaxv002 it is very frustrating i havce tried a blow dryer to heat the r
Your rubber tube is most likely not freezing up and therefore does not need to be heated but only you would know for certain. My experience with ice makes spans several different models but I've found the most common problem for me with no ice being produced is when the bar that shuts of the icemaker gets stuck in the up position because - ice cubes have frozen into a big clump, Ice cubes have jammed the bar by sticking between the ice tray and the bar, or the gear inside that rotates the ice cube tray is stripped in that area because of previous jams and needs to be replaced.
Dec 01, 2014 | Whirlpool Refrigerators
Whirpool icemaker making noises but not producing any ice
Hi
Please check the bellow links to trouble shoot your problem when the icemaker is not making ice:-
http://www.ehow.com/how_4844376_troubleshoot-whirlpool-refrigerator-ice-makers.html
Also check the bellow link for whirlpool icemaker repair guide:-
http://www.appliance-repair-it.com/Whirlpool-icemaker-repair.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Refrigerators
We hooked up water line it has water flow but no ice so far, has been 3 hours. Should we hear someting?
It usually takes about 24 hours to send the first batch of ice through on a new install. Evin if it is an old unit that has been moved. Be sure that the switch is in the on position on the ice maker itself. Hope this is helpful. Good luck.
Aug 16, 2009 | Whirlpool GC5SHEXNS Side by Side...
Icemaker is very slow in putting out ice
Remove the front kickplate and clean your coils (only what you can see) .Also check your settings .An icemaker harvests (operates) at 5 degrees . Operates doesn't look like it's spelled correctly , but you get the meaning .
Jul 06, 2009 | Whirlpool GC5SHEXNS Side by Side...
I am trying to replace the ice maker for my Whirlpool fridge, model number GS5SHGXLS01, I can get the wiring off, please advise?
remove the white cover there is a release tab on end of harness where it goes into IM. push it in and pull wire plug out.
Jun 13, 2009 | Whirlpool GC5SHEXNS Side by Side...
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Ice maker is not making ice, any ideas?
might be the module.this controls the icemaker
Nov 04, 2008 | Whirlpool GC5SHEXNS Side by Side...
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Nov 07, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
122 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
