Audiolab 8000mx power amplifier faults - Audio Players & Recorders
2 Suggested Answers
griffman500
SOURCE: Audiolab 8000 Amplifier User manual/ instructions/Pdf
you could try a website called manualslib.com They have a wide range of manuals etc. for a wide range of car audio makers/models.
Posted on Feb 12, 2014
Why does my Audiolab 8000s mute light stay on?
Your amp is probably in Protect Mode, meaning you have DC Offset( a damaged amplifier). That will have to be repaired, before you can switch the unit on. If you need more assistance, or would like to inquire about repairing it, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
May 30, 2014 | NAD C372 Amplifier
Need user Manual for Audiolab 8000 A Amplifier
http://www.hifiengine.com/manual_library/audiolab/8000a.shtml
Try this...sign up first (free)
Feb 12, 2014 | Audio Players & Recorders
Feb 12, 2014 | NAD C325BEE Amplifier
KE-8000MX lost default password
how i can setup ports to get remot access
Feb 06, 2012 | Home Security
I have an audiolab 8000p power amplifier one channel's dead. \r\n i measured all the voltages etc i can officially say that the output transistors arent on. 0V across them and also heatsinks are dead cold....
Hi
I had the same problem & found a solution that might solve yours, too.
The protection relays are **** quality. One on mine (left channel) got stuck and refuses to close although it gets a signal. I replaced both relays with two OMRON G2R-1 DC 24V 5PIN ones and now everything is back to normal.
Vassilis
Sep 20, 2010 | Audio Players & Recorders
Can i drive 4ohm speakers with an audiolab 800A amp
You can, but you will need to be carefull not to turn the amp up too loud, as it will overload the amp. It would be best to use 8 ohm speakers.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Aug 18, 2010 | ATI Audio Players & Recorders
Buzzing Audiolab 8000M/8000C set up
make sure ur mains supply and ur equipments are compatible. check all connections and most important make sure u have proper earthing.
May 02, 2010 | Audio Players & Recorders
The left channel just went dead on my audiolab 8000p
Hi
The protection relays are **** quality. One on mine (left channel) got stuck and refuses to close although it gets a signal. I replaced both relays with 2 OMRON G2R-1 DC 24V 5PIN ones and now everything is back to normal.
Vassilis
Aug 15, 2009 | Audio Players & Recorders
Eratic volume
Hi....
ONe of the leads on the CD cable has a broken ground (thats why it hums loud)
The speaker that has only the tweeter working: The woofer is blown in the speakers.
Check also for good solid wire connections at both ends of your speaker cables
Mar 29, 2009 | NAD C372 Amplifier
Audiolab 8000CD Player Problem
This may be a problem with the sled motor. This is the motor that moves the optical assembly in and out along a rail. Try openint up the unit and cleaning off the rail with a dry cotton swab. Be careful not the leave any fibers on the rails. Also, while you are in there, clean the lens using another cotton swab and alcohol. Report back with your results.
Dan
Mar 28, 2008 | Audio Players & Recorders
337 people viewed this question
 Grubhead
Grubhead
